Help plzz
Old Jun 24, 2009 | 02:58 AM
behramarbab's Avatar
behramarbab
Default Help plzz
i bought 04 350z trakspec with vdc. when i start the car the car doesnt go fast lyk it doesnt have full power after 5 mins of driving the car comes to normal condition. is it has something to do with vdc.. HELP NEEDED
Old Jun 24, 2009 | 03:11 AM
DavesZ#3's Avatar
DavesZ#3
Need more info. Lots more.
Are the Slip/VDC off/ ABS or brakes lights coming on?
Can you rev the engine over 2000 rpm or does there appears to be a low rev limit?
What are your front and rear tire sizes?
Have you done any work to the car, suspension, wheels/tires lately?
Old Jun 24, 2009 | 03:20 AM
behramarbab
no they are all off.yes i can rev the engine but wen i start the car it revs slowly lyk not normal.afta 5 mins then it comes back to normal tyres sizes fron 225 40 r18 rear 245 40 r18
Old Jun 24, 2009 | 03:51 AM
DavesZ#3's Avatar
DavesZ#3
With no lights coming on, it's probably not VDC or TCS kicking in. A malfunction would usually cause all the lights to come on at the same time.
It almost sounds like you're in "limp mode" but that usually prevents you from reving over 2000-2500 rpm and it wouldn't go away after 5 or 10 minutes.
Since it does goes away after the car warms up, it might be some sensor that is going bad but it's impossilbe to guess which one it might be. You're probably going to have to take it to a dealer and get it hooked up to the computer to see what's going on.
Old Jun 24, 2009 | 05:27 AM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Jun 25, 2009 | 09:35 AM
vthao's Avatar
vthao
When you first start your car, the engine is still cold and the ecu knows this. Because of safety issues such as insufficient oil lubrication messing up the motor, the ecu limits what you can do until the motor has warmed up. This is normal for any car with a stock ecu.
Deltmooro
Jan 31, 2013 06:28 AM
ysfg35
Oct 22, 2008 07:17 AM
keosh
Southern California
Sep 18, 2007 02:13 PM
