my power seats going to die soon
Recently i have been noticing my power seats struggle sometimes not working when i want them too. I want to change this out asap before i get stuck in the postion i dont want to be in.
does anybody know the part number or where i can find the motor for the seats. i dont want to go to the stealership because they will charge me a arm and leg?
so is the seat accually moving but havin a hard time?
or are the seat controls not reasponding?
my seat controls didnt reaspond, but i sprayed some electric cleaner on them and they work like new!
hope this helps
hope this helps
I believe this is a switch issue, and not a motor issue. The contacts
wear out prematurely - causing the seats to struggle like you mention.
These are easy to replace, though expensive at the dealer - roughly $75 each.
This stuff is a life saver! Just spray it on the switch, and work it back and forth and it should start to work, if not, it may be the actual motor.
The switches tend to get a lot of dust and junk in them since they face straight up. This should do the trick!
Well i did this today and sprayed it right on the switches. I works better than before it doesnt get stuck as often but i might have to lube the seat rails too just to make it better. Thanks for the help on here
