idle problems 2003 350Z
Old Jul 10, 2009 | 03:47 PM
topper10's Avatar
topper10
Question idle problems 2003 350Z
idle is steady at 1000 rpms cold at operating temp and when slowing down to stop or turn press clutch and idle drops low sometimes dies and other times drops to 500rpms goes back to normal at low part of idle sitting still the engine will diseal runs fine at speed any body got some help thanks all
Old Jul 10, 2009 | 03:49 PM
Zolid's Avatar
Zolid
it looks like english, but somehow i cant understand it.
Old Jul 10, 2009 | 03:57 PM
topper10's Avatar
topper10
Default idle
idle will speed up and down when running when engine at temp idles fine cold hope this helps thanks all idle speed sensor maybe dont know thanks all
Old Jul 10, 2009 | 04:05 PM
freedonutss's Avatar
freedonutss
Will you use periods and commas please? Cant understand a damn thing your trying to say
Old Jul 10, 2009 | 04:11 PM
topper10's Avatar
topper10
sorry my engines idle, will drop and go back normal when car is at a stop light. it like a govner on a lawn mower. sorry if i offended anyone
Old Jul 10, 2009 | 04:15 PM
freedonutss
For a start, clean your maf and throttle body. Then a full ECU Reset. How many miles on your car?
Old Jul 10, 2009 | 04:24 PM
topper10's Avatar
topper10
102,000, just bought it. this is the only problem i have. runs great. lots of extras. ACM cold air intake. hope this helps more. thanks for any help
Old Jul 10, 2009 | 04:29 PM
topper10's Avatar
topper10
how do you do a full ecu reset? will unpluging the battery do it? my first Z
Old Jul 10, 2009 | 04:43 PM
Zolid's Avatar
Zolid
dont you mean AEM intake? For the reset, you can do a "soft reset". Unplug the negative battery terminal and hold down the brake for 5 minutes and that will reset the ECU.
Old Jul 10, 2009 | 04:46 PM
topper10's Avatar
topper10
yes AEM sorry finger slipped. thanks for your help!!!!!
Old Jul 10, 2009 | 06:40 PM
neox's Avatar
neox
Thats like saying unplug the negative battery terminal and hold your finger on your nose for 5 minutes. If there's no ground the ECU is getting no power therefore it will reset, no need to push any pedals.
Old Jul 11, 2009 | 09:01 AM
doncesar's Avatar
doncesar
lol at the brake hold
Old Jul 11, 2009 | 03:06 PM
jerZey 350's Avatar
jerZey 350
Mass Air Flow Sensor(MAS)
Old Jul 14, 2009 | 04:25 PM
Z&G's Parts Dis's Avatar
Z&G's Parts Dis
Vendor - Former Vendor
Putting finger on nose helps
Old Apr 28, 2013 | 06:57 PM
JimmyJump's Avatar
JimmyJump
Default Was it fixed?! And how?
I think I'm having the same issues as this guy but its hard to understand what he is saying so idk.
*was this problem fixed? And how?**
My problem- when I have my vehicle in neutral idle is steady around 1000RPMS. when I'm driving the vehicle and throttling it hard and take it out of gear, it will drop to 500rpms then stall. It doesn't do it all the time.
Any input?
I got a 03 350z. 113k on it.
Old Apr 29, 2013 | 06:42 AM
Spooky's Avatar
Spooky
I had a similar problem before. Cleaning the mass air flow sensor, and cleaning the throttle body solved it for me.
Old May 4, 2013 | 04:13 PM
JimmyJump's Avatar
JimmyJump
Did you remove the parts and cleaned it or did you use a additive in the gas?
Old Jul 19, 2019 | 12:41 AM
Trafael77's Avatar
Trafael77
I’m having this exact same issue on my 04’ 350z. My car will idle roughly at around 500-700 rpms then sometimes just turn off in neutral. It even turned off when I put it in neutral going 50 mph. I’ve replaced both camshaft position sensors since it threw me a code about 3 weeks ago. But this issue remains. Any ideas on what it could be? No check engine light has shown itself. I’m thinking something electrical? Or maybe not enough air flow? Any help would be greatly appreciated!
Mods:
no brand cold air intake
greddy exhaust system
Old Jul 19, 2019 | 05:43 PM
mr. sparco's Avatar
mr. sparco
Mods:
Try that.
Old Jul 20, 2019 | 05:39 PM
Gage18's Avatar
Gage18
Default 350z dies at idle
Hi everyone,
i need yalls help!! My 2006 350z does every time it’s left in idle The rpms keep fluctuating then it just ends up dropping. I have cleaned throttle body replaced camshaft sensors and maf sensor. I was thinking crankshaft sensor but idk . I have no engine light .
