Engine dies after ECU reset
Old Jul 16, 2009 | 07:17 AM
rocketscience's Avatar
rocketscience
Default Engine dies after ECU reset
So basically, two weeks ago I did my first oil change on my 03 Z, purchased about 3 months ago, used Mobil 1. The next day I spent installing an aftermarket audio head unit, so I had the battery unplugged. This I assume reset the ECU in the process.
Since that weekend, many times I have come out and started my car and it will turn over then the RPM drop too low and it stalls. I then usually restart the car and give a little throttle to keep this from happening a second time. It's only hot starts, since with cold starts the idle is higher during initial starting.
This is kind of annoying and embarrassing, i was hoping it was just a learning curve for the ECU and it would stop, but its been two weeks. Any ideas on how to remedy this?
Old Jul 16, 2009 | 08:42 AM
EE Z's Avatar
EE Z
Try cleaning your throttle body
Old Jul 16, 2009 | 10:08 AM
Waiz's Avatar
Waiz
Sounds like an idle-learn was not reset properly after the reset.
You will need to take it to a shop to have the relearn placed.
Take it to Precision Z in Canoga Park and have them take a look at it.
Old Jul 16, 2009 | 05:06 PM
kevincat's Avatar
kevincat
just do an idle relearn and that should fix it. or just ignore it for a few days and it will perform the relearn itself. no point of paying 90 dollars to a nissan dealership.
Old Jul 19, 2009 | 01:43 AM
rocketscience
Thanks for feedback. I tried the Idle relearn procedure, but that didn't seem to help. So i did a reset of the ECU, this time with the pedal procedure. So far so good, hope it takes!
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
