Where to connect 134a refrigerant recharge kit? Need pic, please
Old Jul 16, 2009 | 08:21 PM
RichardS_VA's Avatar
RichardS_VA
Question Where to connect 134a refrigerant recharge kit? Need pic, please
Looking for the low pressure valve fitting to connect the standard 134a refrigerant recharge kit (bottle, hose, gauge, fitting) in a 2006 350z.
Picture would be great. Thanks.
Old Jul 16, 2009 | 08:25 PM
Russ@Z1's Avatar
Russ@Z1
Rear driver's side corner of the engine compartment.
One connection is outside the brake compartment and one is inside. Just pop the cover and you'll see it there.
In this pic, you can see one cap leaning towards the master cylinder on the inside of the compartment, and one outside the compartment near the intake tube.
Old Jul 16, 2009 | 08:44 PM
RichardS_VA
I was thinking this was the connection (pic is from g35 engine bay). Is this not the correct location?
Old Jul 16, 2009 | 08:46 PM
RichardS_VA
Russ, thanks for the picture, that is worth more than 1000 words!
Old Jul 16, 2009 | 09:26 PM
davidmcc's Avatar
davidmcc
Be careful how much refrigerant you add, too much could cause the system to not work properly either
Old Mar 20, 2016 | 10:15 PM
3polxin's Avatar
3polxin
well, some measure of refrigerant that you add must fit. because as it is in say Mr. David that adding too many possibilities to make the system work is not optimal.
Old Mar 21, 2016 | 02:56 PM
zakmartin's Avatar
zakmartin
Richard, if you don't have a AC manifold, and you don't know what you're doing or where to hook up, do yourself a favor and take it to a garage to get the system purged and refilled. They'll check the pressure and vacuum to see if you have any leaks and they'll put in the exact right amount. It shouldn't cost you more than $100-$150. If you do it yourself with one of those cheap refill kits with the "universal gauge," without knowing exactly what you're doing, you're likely to do more harm than good.
350Z_Al
Oct 29, 2020 07:44 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
