starting problems, 6speed
Old Aug 2, 2009 | 01:06 PM
nspec's Avatar
nspec
Default starting problems, 6speed
not asking for diagnosis as it would be very hard to do online.
but just curious if anybody else here had this problem with theirs.
My Car: 03, 35k miles, Touring, 6speed.
Every now and then, the engine wont start, it will turn freely, but wouldn't start as if there was no fuel or spark.
The only thing I can guess is that after a little bit of rough/hard driving, if I turn the motor off for a minute or two, then start it again, it would do that.
This happened once about a month ago, but twice today.
I had to wait for about 5 minutes before giving it another crack and then it starts right up as if there was nothing wrong.
Old Aug 2, 2009 | 04:55 PM
nspec's Avatar
nspec
it can't be the battery because the motor cranks freely without any struggle.
I doubt its the spark plugs either because it would misfire continuously.
Thanks for the reply.
Old Aug 2, 2009 | 07:55 PM
vthao's Avatar
vthao
You can check your fuel filter to see if it needs replacing, they're usually pretty cheap. Also try cleaning your MAF by spraying a little carb/brake cleaner at it and letting it air dry. At 95k miles, it could very well be your spark plugs faulting as well.
Old Aug 3, 2009 | 06:58 AM
Boogshag's Avatar
Boogshag
run an OBDII on it and check the code
Old Aug 3, 2009 | 03:52 PM
nspec's Avatar
nspec
thanks for the replies.
no CELs at all.
any body who actually had a similar problem before?
Uriyo_
Sep 8, 2021 08:46 AM
