Interior Passenger Door Handle
Old Aug 2, 2009 | 03:52 PM
coletrain12's Avatar
coletrain12
Default Interior Passenger Door Handle
Hey guys, have a 2003 touring 350z. The handle on the passenger side on the interior is pretty much broken. The bottom pops out when you pull on it and at the top where it connects to the door it pulls out really far when you pull on it. Looks like the plastic that holds it on has broken.
Anyone have this problem before and find a fix? I haven't popped the door panel off yet to take a look, but im unsure if you can even fix it. I don't believe a new handle would do anything.. it looks as if I would need to buy a whole new door panel to fix it. Anywhere you can purchase a whole door panel?
Thanks
Old Aug 2, 2009 | 03:59 PM
BlueZ33's Avatar
BlueZ33
you might be able to get away with just using a different screw if the threads are stripped or if it the plastic one all you would need is a new clip to go in the door
i would recommend taking the door panel apart and confirming it for sure
it should be an easy fix
Rev_Night
Nov 7, 2020 06:00 PM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
