rough idle after changing out the battery
Old Aug 25, 2009 | 05:42 PM
lafingas's Avatar
lafingas
Default rough idle after changing out the battery
heres the low down....
after my battery crapped out on me i changed it....now it cranks up smooth and great!!!
But.....
as soon as the engine starts and the rpms come bak down to idle it doesnt stop at idle...they drop almost to where the car dies..like to where all the dash lights come on...then the rpms shoot back up to ide (bout 500 -750 rpms)....
like i said...its only happens after the initial start up....once the revs come bak up ..the car idles fine....and drives fine
to me it seems the ecu was reset..which is normal but why the rough idle now????....do i have to adjust the idle???...if so how????....the car idled fine before....
any help would be praised.....
Old Aug 25, 2009 | 08:03 PM
Very common. Leave the car alone for several days. If idle does not fix itself reset ECU.
Old Aug 27, 2009 | 10:17 AM
lafingas's Avatar
lafingas
i guess....i will try that...if it doesnt work...ill reset the ecu..hopefully thatll take care of it...
Old Aug 27, 2009 | 02:43 PM
DavesZ#3's Avatar
DavesZ#3
The dead battery essentially reset it for you already.
Old Aug 28, 2009 | 04:12 AM
lafingas's Avatar
lafingas
^^^^ So what could be causing the initial rough idle
Old Aug 16, 2023 | 06:45 PM
Cia.Z33's Avatar
Cia.Z33
any update?
Old Aug 17, 2023 | 06:39 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by Cia.Z33
any update?
Je parked it 14 years ago? 🤣
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
