Overheating while parked but once moving no issues. Please help
Old Jan 28, 2010 | 01:31 PM
ZRated67's Avatar
ZRated67
Do you live on Venus?
Old Jan 28, 2010 | 03:43 PM
Spike100's Avatar
Spike100
I’m guessing there is trapped air in the system. The symptoms are running hot at idle, and the heater throws cold air; when you accelerate, the engine temperature drops and you get warm air from the heater.
To fix this, you open the air bleed in the radiator hose that is near the firewall while adding coolant.
--Spike
Old Jun 10, 2010 | 02:27 PM
stoffius's Avatar
stoffius
Having same problem as OP. Car runs fine without a/c no matter outside temp or speed. However when a/c is running and car stopped, it quickly overheats. Upon moving, temps immediately lower.
Both fans run, fluid levels ok.
Bad Thermostat?
Old Jun 25, 2010 | 03:09 AM
Synjn's Avatar
Synjn
Originally Posted by defnowtones
cool thanks guys. checked the fans they are on but car still overheating.
Wait a sec, the fans are on but it still overheats? And when the car is in motion the temp is fine?
Try this: While the car is NOT in motion, fans on, car starting to overheat, rev the engine to about 3k and hold for 4 or 5 sec. See if temp shoots down.
If so thermostat could be stuck closed, and its needing the water pump at rpm to open it and circulate the water.
ablaine
Nov 29, 2016 10:13 AM
Fixxxercask
Nov 9, 2015 11:10 AM
