My 350 is screeching when i start it up, and this only happens during the cold season
Old Jan 22, 2010 | 07:56 AM
at350zguyy's Avatar
at350zguyy
Default My 350 is screeching when i start it up, and this only happens during the cold season
Does anyone else experience this too?
I am triyng to figure out what it is and how to get rid of it. It is really annoying. It happens right at startup and then after I come to a stop and start driving again. Also happens while turning sometimes.
I've read somewhere that this could be the belts being loose. Is this true?
Thanks in advance.
Old Jan 22, 2010 | 08:07 AM
DB350's Avatar
DB350
yeppers, sounds like wet or loose belts
Old Jan 22, 2010 | 08:09 AM
Entaille's Avatar
Entaille
what DB said. your belts could simply just be wet.. or they could be loose.
Old Jan 22, 2010 | 08:14 AM
VO...'s Avatar
VO...
Administrator
It's your belts. Time to replace...
Old Jan 22, 2010 | 08:27 AM
PerfZ's Avatar
PerfZ
Spray some WD-40 on them - if the problem goes away temporarily, that's your answer.
Old Jan 22, 2010 | 09:26 AM
diablox1's Avatar
diablox1
loose or cheap crap belts ftl
Old Feb 3, 2010 | 10:20 AM
domsaywha's Avatar
domsaywha
Im having the same problem guys. What belt is this that has to be changed?
Old Feb 3, 2010 | 11:12 AM
thekinn's Avatar
thekinn
Just change them both at the same time. It's cheap and easy.
https://my350z.com/forum/engine-driv...very-easy.html
Old Feb 4, 2010 | 08:23 AM
chromesilverz's Avatar
chromesilverz
Might as well change them both...it so cheap and easy.
Old May 21, 2010 | 08:04 PM
at350zguyy's Avatar
at350zguyy
anyone know how expensive this job is if you bring it to a shop?
Old May 21, 2010 | 08:34 PM
Synjn's Avatar
Synjn
Don't pay anyone to tighten your belts. That's ridiculous. My girlfriend can tighten belts. If i showed her how.
Go pick up a repair manual from your nearest pep boys, borrow some tools from a friend. Would take an unexperienced person no more than an hour.
And you can say you did it yourself!
ps: I don't recommend spraying wd-40 either. lol
Old May 22, 2010 | 09:02 AM
at350zguyy's Avatar
at350zguyy
has anyone here brought this issue to a shop to see how much it costs?
also, i have a problem with my passenger window...i think the motor needs to be reset since it doesnt respond to the switch anymore. anyone know how to reset the motor?
Old May 22, 2010 | 07:54 PM
at350zguyy's Avatar
at350zguyy
also, anyone recommend a place to get the 60k service done? and out of the things they suggest, is there anything unnecessary in there?
Old Jun 1, 2010 | 03:47 PM
Armed Ferret's Avatar
Armed Ferret
Less than 10 posts and I already get to be helpful....woohoo!!
Here's a great thread that details, among other things, how to reset the windows:
https://my350z.com/forum/maintenance...dow-motor.html
Old Jun 1, 2010 | 03:58 PM
zer0cool's Avatar
zer0cool
It's the alternator belt. Look at ur voltage gauge. I garantee that it drops to 12 while screeching. Tighten it up and you should be good to go.
Old Jun 25, 2010 | 03:11 AM
Synjn's Avatar
Synjn
tighten your damn belts.
samansharif
Sep 25, 2015 12:31 PM
