Squeeling from front right wheel
Old Oct 13, 2009 | 09:02 PM
Joecoolly14's Avatar
Joecoolly14
Default Squeeling from front right wheel
I know theres a thread on this somewhere, but I searched and couldnt find it. Whenever I make a left turn, my front right wheel will *squeak squeak squeak*. The other thread said something about one of the clips on the caliper was rubbing on the rotor. Have any of you heard anything like this?
Thanks in advance
Old Oct 13, 2009 | 11:26 PM
rcarr88's Avatar
rcarr88
Yes I have had this before, not on my 350z but it did happen on my 300zx, if it is a more high pitched noise, but still seems pretty noticable then it is most likely your brake pad indicator that has been bent and it rubbing your rotor. Take it to your local tire shop if you cannot find it and they should be able to spot it no problem. Generally means that it is close to time to get new brake pads as well. Hope this helps.
Old Oct 14, 2009 | 01:44 AM
Dark8lue's Avatar
Dark8lue
oh ok iwell i was gona say new brakes^^what he said
Old Oct 14, 2009 | 08:24 AM
Joecoolly14
Ugh new brakes already, lol Ive only got 11k! hahah Thanks for the info
Old Oct 14, 2009 | 10:26 AM
crash1555's Avatar
crash1555
i had this happen turned out to be a small pebble stuck between a cover and the rotor i think..
this was with a mini cooper after i got the front end stuck in some mud...
could be something else though
Old Oct 14, 2009 | 12:27 PM
rcarr88's Avatar
rcarr88
Just take it to get looked at, tell them you have a squeeking noise coming from your right front tire and tell them to have a look at the brake pad warning indicator.
Old Oct 14, 2009 | 01:05 PM
Motormouth's Avatar
Motormouth
don't tell them it's coming from the tire.
Old Oct 14, 2009 | 02:47 PM
winchman's Avatar
winchman
The fact that it happens only during left turns suggests the right front wheel bearing may have excessive play, allowing the relationship between the rotor and caliper/cover to change as a side load is placed on the bearing.
Old Oct 16, 2009 | 03:08 PM
Joecoolly14
Yeah I was either thinking it was a wheel bearing or the pad indicator. Ill take it in this weekend
Obadabot
Jun 18, 2023 11:31 PM
