Clutch Engage Problem?
Old Nov 4, 2009 | 01:14 PM
TouringThe350's Avatar
TouringThe350
Default Clutch Engage Problem?
Let me ask those who have a 6MT, if your Z is in neutral and you let off your clutch pedal, is there a kind of whirling consistant noise when idling? If you let off the clutch pedal very abruptly when in neutral, does the car slightly move? And when you press the pedal back in, does the sound go away? I can get video of the noise if needed.
My car has done this for quite some time, at least a year, and I happened to drive another Z today and this car did not do this at all. No other manual trans car I have had has done this either. 53,000 Mile, on 3rd transmission, new clutch installed by dealership @ 49,000 miles.
Old Nov 4, 2009 | 01:16 PM
HCJOE's Avatar
HCJOE
Yes, no, yes.........................................
Old Nov 4, 2009 | 01:25 PM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Dont know about WHIRLING but I have chatter.. My car doesn't move if I'm in neutral and let off the clutch..
I do have an aftermarket clutch though -
If your under warranty - just get it fixed..
3rd tranny! WTH? And I believe my clutch went out about the same time - about 55K..
Old Nov 4, 2009 | 02:37 PM
sdZ33's Avatar
sdZ33
I think I know what your talking about, when in neutral it does sound like a whirl noise that's consistent with the idle,kinda like your fan turned on, right? Then you press the clutch and it goes away? That's just the clutch chatter, it's normal, all Z's have it, some louder than others, but trust me, it's there!
For the second question about the car moving... I have a problem when I'm like in second gear coming to a stop sometimes, I put the clutch in and it feels like a big bang and the whole car shakes, sort of like something is loose(I'm thinking it could be a motor mount or tranny mount, but I'm no mechanic, so I'ma take it to the stealership).
Old Nov 4, 2009 | 02:43 PM
dmroberson's Avatar
dmroberson
I've always had clutch chatter... It's worse now, with the ACT ProLite flywheel.
Old Nov 4, 2009 | 04:23 PM
juelz86z3303's Avatar
juelz86z3303
Thumbs up clutch
hey may need them to look at they work. dam thats sad.. my story i took my z to ge it loked at and i had my girl take it for me they told he its an transveral mount tranny. they wante 2300 to do my stock clutch over hahaha. i told her to go get my car fromthem and i will get an aftermarket clutch jim wolf cutch flywheel stage 2.. maybe its your throw outbearing . i get a whinig noise .but i know the z tranny is very noisy. but you can change you master clynider. this may not stop ur chattering but if it does you will know the diffrence.. also open it up and inspect that may be out of place. for he problem you ecperiencing... oringinal motor and trans with 142555 and counting. running strong.. take it back and complain thats all nissan is so scandalist. but thats how they make they money sticking it to customers...
also my stock clutch lasted until i upraded sit still was in good condition with massive clutch material too. but my mother in law threw it away... with my pressure plate and all. she is nutz i told her that is was still worth money. crazy lady
Old Nov 4, 2009 | 05:13 PM
Don't know how the car will move in neutral. The transmission is supposed to be disconnected from drive train. THe transmission must be broken.
Old Nov 5, 2009 | 12:17 AM
sdZ33's Avatar
sdZ33
I would have punched my mother in-law in the face if she did that to me!
Old Nov 5, 2009 | 02:53 AM
TouringThe350
Thanks for the replys! Sounds like the noise is common. The car only moves 1/2 inch or so and that's it and only does so when the clutch pedal is let off quickly. I'll get some vids today, maybe you gys can tell me my car sucks and it's broken. After 3 transmissions in 12,000 miles, I'm freakin paranoid.
Old Nov 5, 2009 | 02:55 AM
TouringThe350
Yep, that is exactly it... damn is it annoying! I also get the "clunk" into second or first when comming to a stop.
Old Nov 5, 2009 | 04:01 PM
sdZ33's Avatar
sdZ33
Well everything seems to run fine on the car other than that annoying clunking noise and the shake... but i took it to the dealer and tell them to look at it all the time when i go in for an oil change and they say yea but they never do... but next time ima raise a lil hell there! ...
Just take it there and let them know specificly whats going on... And ask to explain it to a tech not a service writer, cuz they'll probably ignore it, just like they did me... GL bro!
Old Nov 5, 2009 | 04:29 PM
binder's Avatar
binder
never should the car move with the transmission in neutral.
are you sure you're not on a slope or maybe there is a bump your tire rests on when you park?
When the car is in neutral the transmission should not engage the output shaft thereofre you could push the clutch down and move your foot to let it slam back up and the car won't move....unless something is broken.
it's either in your mind or something is broken.
Old Nov 5, 2009 | 04:44 PM
aaronz8's Avatar
aaronz8
i also get whirring, but no movement. good luck
Old Nov 5, 2009 | 05:01 PM
sdZ33's Avatar
sdZ33
It doesn't move when it's in neutral really...
Let's say I'm in first or second, and I'm going maybe 15-20 mph and you press the clutch, instanly right when you press the cluth you feel the shake and then immedeatly the clunk follows... I know it's not normal and I personally think it's a mount or something... but like i said im no mechanic so ima take it in....
Old Nov 5, 2009 | 05:46 PM
binder's Avatar
binder
oh, well that i'm not sure about. I'd have to hear it. It might just be the clutch disengaging.
I was confused on the whole "car moving when in neutral" thing.
Old Nov 8, 2009 | 06:26 AM
gabe74gt's Avatar
gabe74gt
not really. had heard about a problem like you have. may be you need to get the clutch plates near to each other. there may have some space evolved in between. and whirring is often
Old Nov 9, 2009 | 07:45 AM
juelz86z3303
Wink
word up she lucky her daughter is why didn't but. duded i think your tranny maybe toasted i dont want to come off like an *** hole but. i cant think of anything eles that can be your problem.. just search around for another tranny as hard as that is cause the z is still fairly new.. did you drain you fluid in your transmission, routenly. maybe its doesnt have no and it could be fried or thats the tranny calling out to you like i need to be drained or something.. i will try to find another tranny and then.. drop my old one and check/ verify all parts be fore moving forward. you have to remember the z tranny is so advance. its not like the 370 with syncro rev but it has still have its limits...
Old Nov 10, 2009 | 08:51 AM
binder's Avatar
binder
transmission is new. There is no problem with it.
the clutch was welded to the flywheel and i had to pry it off. The inspection says it's fine and needs to be cleaned up to use.
I installed an OS giken twin disk while i was waiting for the clutch and everything is fine. I'm going to keep this 6 puck as a backup in case something happens to my OS.
Old Nov 10, 2009 | 10:17 AM
akbayati1287's Avatar
akbayati1287
I also noticed the noise in neutral when i engage/disengage the clutch. A friend of mine with a Z told me that it was common in Z's and that its just the throwout bearing . . . stupid noisy nissan transmissions
Old Nov 10, 2009 | 02:17 PM
binder's Avatar
binder
wow, i just noticed this wasn't the thread i thought it was when i posted the above comment. LOL
i thought this was the thread about my clutch not disengaging. Disreguard what i said, i haven't slept since sunday night.
