Need help with Z trouble.
Old Oct 15, 2003 | 11:19 PM
ZDUB's Avatar
ZDUB
Default Need help with Z trouble.
Hey guys, this might be a repost but i seriously need help on this annoying clicking noise coming from the rear passenger side tire. It sounds like loose change. I took it to the dealer two days ago, and they said they tightened all the bolts and the sound was gone. So I picked up the car, as soon as the tech was driving it to me I could hear it. I talked to my service rep., he said to drive it cause they could not duplicate the sound. So I told my rep. if one of the techs can ride with me and I will show him. And for sure enough it was there. They tried to find what was causing the problem but they couldn't. They said to bring it in another day, so they can spend time on it. Do any of you guys have this problem? If you do, can you tell me how to fix it. That way when I bring it back to the dealer I can point it out to them. Thanks guys.
Old Oct 16, 2003 | 05:26 AM
the doc's Avatar
the doc
I have what seems to be a 'chirping' or high pitched 'tinging' sound in that area. I have reason to believe it's something inside the hatch lid, but I haven't had time to remove the plastic to check it out. It's really annoying, so I usually have the windows down or radio up!
Old Oct 16, 2003 | 05:48 AM
Rxramon's Avatar
Rxramon
Charter Member #45
CHECK the spare tire and JACK... The jack could be a little loose, as it is held only with velcro.....
Old Oct 16, 2003 | 05:50 AM
the doc's Avatar
the doc
good thought!
Old Oct 16, 2003 | 02:55 PM
ZDUB's Avatar
ZDUB
[QUOTE]Originally posted by Rxramon
[B]CHECK the spare tire and JACK... The jack could be a little loose, as it is held only with velcro.....
I'll try that......thanks, I'll let you know if it worked/
Old Oct 17, 2003 | 02:30 AM
ZDUB's Avatar
ZDUB
checked the spare tire and jack...........noise still there......gilbert
Old Oct 17, 2003 | 11:29 AM
Rxramon's Avatar
Rxramon
Charter Member #45
Do you have a rock in your tire tread... thats an annoying sound too...
also if you have splash guards, one may be a little loose... i tightened mine a little..
Old Oct 17, 2003 | 10:30 PM
ZDUB's Avatar
ZDUB
The noise still there..........
DavesZ#3
Jun 13, 2009 03:29 AM
geez zee
Nov 3, 2006 05:57 AM
