Flushed manual tranny fluid...GL5???
Old Jan 7, 2010 | 08:08 PM
cababah's Avatar
cababah
Default Flushed manual tranny fluid...GL5???
Just took my car to a shop to get some work done and decided to have them service the manual transmission by draining the OEM fluid. This shop does exclusive work on nissan/infiniti cars but after I get home I check the invoice and see:
NEO SYNTHETIC HD RACING FLUID 75W-90
I called this company and found out it is a GL5-GL6 fluid which is warned against using in our transmissions. I called up the guy who works for this company (NEO) the owner actually, and he said I would know within a week if the high sulphur was damaging the brass in my synchros. I have had almost 2,000 miles on the car since the fluid and actually it shifts better than before. I no longer get cold gear grinds going from 1-2.
Since it has been a few weeks and a couple thousand miles and it seems to be shifting smoothly, does that mean this fluid is okay to keep in the car?
I will be getting my rear diff fluid serviced tomorrow so I am wondering if I should just flush the manual fluid with OEM GL4 to be safe or just keep the NEO in there since it is shifting okay?
Old Jan 7, 2010 | 08:17 PM
tw8715's Avatar
tw8715
i would change it to the gl 4
probably shifting better cause its a sythetic lube in there right now.
try using amsoil, thats what i put in mine.
TRANNY: http://www.amsoil.com/StoreFront/mtg.aspx
DIFF: http://www.amsoil.com/storefront/svg.aspx
they meet all the specs too
Old Jan 7, 2010 | 09:34 PM
PV350Z's Avatar
PV350Z
how much did that cost?
Old Jan 8, 2010 | 01:57 AM
duro78's Avatar
duro78
how many miles did you have on your car?
Old Jan 8, 2010 | 08:03 AM
cababah's Avatar
cababah
I had about 55k when the service was done
guess I will just replace the diff and manual fluid today while I am at the dealer..I just hope there wasn't too much damage done from having it in there for 2k miles...
Old Jan 8, 2010 | 09:48 AM
DavesZ#3's Avatar
DavesZ#3
Although the Z calls for a GL-4, there are some GL-5 gear oils that are okay for the transmission. Royal Purple meets GL-5 specification, but is compatible with the brass material in the syncros. You need to find out if the lube you used is true GL-5 and see if it warns against use in transmissions that require GL-4.
Old Jan 8, 2010 | 10:25 AM
dmroberson's Avatar
dmroberson
+1. I use Redline Oil, which is GL-4, so there's no guessing game for me...
Old Jan 8, 2010 | 12:41 PM
DavesZ#3's Avatar
DavesZ#3
I just switched to Redline on my last change. Shifting is a little easier but from the looks of it, gas mileage has dropped some.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
NiLL
Nov 29, 2021 02:26 PM
SharX59
Sep 27, 2015 09:23 AM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
