Cylinder #1 Misfire
Old Feb 22, 2010 | 07:34 PM
al_stew2000's Avatar
al_stew2000
Default Cylinder #1 Misfire
Hey guys I've got an '03 touring that I've had for about a month and a half. The other day it started to sputter just a little when you first turned it on and the CEL light came on. The code says that its a cylinder 1 misfire. It seems to run great through all of the gears its only when you first start it. Any ideas where to start? I took the spark plug out and the gap was .65 instead of .43 and the plug also has a pretty heavy gasoline smell to it. I fixed the gap and put it back in. That maybe helped a little but it still does it some. I haven't had time to do anything else with it. Any help would be great! Thanks!
Old Feb 23, 2010 | 04:03 AM
*Boose*'s Avatar
*Boose*
What's the mileage? How is/was the maintenance upkeep? Have you done any replacements of any key parts?
Old Feb 23, 2010 | 06:44 AM
al_stew2000
Mileage is 96k and the records show regular oil changes and tune ups etc. I haven't done anything to it accept change the oil. The plugs are NGK's I don't know when the last time they've been changed.
Old Feb 24, 2010 | 03:48 AM
Vas_Z33's Avatar
Vas_Z33
Maybe a coil pack ?
Old Feb 24, 2010 | 01:18 PM
al_stew2000
Yeah I thought it could be that. I'm going to try a new set of plugs this weekend first and see if that helps out any. If not then I'm gonna try a new coil. My CEL went off but it's still having the same problem...go figure.
Old Feb 24, 2010 | 03:14 PM
OrleanZ33's Avatar
OrleanZ33
I would suggest swapping coils with Cylinder #3 first, if the problem follows to that cylinder you know its the coil pack.
Old Feb 24, 2010 | 06:59 PM
al_stew2000
I just did that this evening. I'm waiting for the CEL light to kick back on and see if the code moved to the other cylinder. Hopefully thats all that is wrong.
Old Mar 8, 2010 | 06:37 PM
al_stew2000
Well I swapped the coil packs and the CEL light kicked back on. Still says cylinder 1 misfire. I'm thinking about buying a new fuel injector and giving that a try. Any more advice or anything else to try?
Old Mar 11, 2010 | 05:32 PM
MTZ33's Avatar
MTZ33
could be a leaking exhaust valve or burned valve causing the cylinder to lose compression..if not that, ur A/f mixture is off in that cylinder.. clogged injector or defective injector..
Old Mar 12, 2010 | 09:26 AM
al_stew2000
Thnx for the reply. Are there any easy ways to check and see if that could be the problem?
Old Mar 12, 2010 | 09:43 AM
TheFarmer's Avatar
TheFarmer
Compression and leak down tests
Old Mar 12, 2010 | 09:58 AM
al_stew2000
Thanks guys! I really hope thats not the problem. Would it cause it to happen only when cold?
Old Oct 19, 2013 | 01:15 PM
NOLAGG's Avatar
NOLAGG
Bumping old thread that is exactly what I'm going threw with cylinder 2 . The sputtering at idle , and cel on and off always reading cylinder 2 missfire . I switched coils , replaced the plug and also did a compression test . What's the next move one of you guys think I should do ? Replace injector ? Thanks !
I'd like to add that the misses I'm experiencing at idle sound like someone is punching the motor .
Old Oct 19, 2013 | 06:29 PM
NOLAGG's Avatar
NOLAGG
Here's the link to the video I made of it misfiring 20 mins ago
Old Oct 19, 2013 | 06:34 PM
jerryd87's Avatar
jerryd87
ohm the injector and see what the resistance is vs the other injectors
Old Oct 19, 2013 | 07:59 PM
NOLAGG's Avatar
NOLAGG
I will probably do that and have a new oem iniector ready incase thats the problem . Two questions . 1 do you know how many ohms a good working injector should be reading ? And 2. When I remove the plenum should or do I have to replace anything gaskets ect ? Thanks !
Old Oct 19, 2013 | 08:36 PM
jerryd87's Avatar
jerryd87
some people have had lucky reusing the gaskets but i would replace them. not sure on what stock resistance is on them but they will all be the same, if one is outa wack you will see it on the readout. i would test at the ecu connector though not right at the injector. if they show good you would be wasting your time replacing gaskets for no reason.
Old Oct 19, 2013 | 10:06 PM
NOLAGG's Avatar
NOLAGG
I thought since you have to remove the plenum with gaskets to get to the injectors to even test them ? Please enlighten me as I will check tomorrow if I don't need a gasket set on hand
Old Oct 19, 2013 | 10:24 PM
jerryd87's Avatar
jerryd87
no unplug the ecu, the injectors have one wire that is constant power on the fuse block, should be the one in the driver side kick panel, fuse number 1 10 amp. pull that and use a needle probe or a piece of wire to stick in there and connect the wire with a alligator clip to one probe of the multimeter. then the other probe you touch to pins 23,22,21,42,41,40 of the ecu connector thats the wire the ecu uses to ground the injector and open it. they should all be similar in resistance and pin 42 is injector 2. page ec-594 for wiring diagram. pulling the plenum is way to much work for a simple check plus always start at the source.
Old Oct 20, 2013 | 05:55 AM
djamps's Avatar
djamps
Sounds like mine when I had a cracked plug causing blowout. But if you already checked sparks and coils that it's more likely a cracked ring or other major engine problem. It's almost amusing how many times people think their injectors are bad and almost NEVER is an injector the cause of the issue in the end.
