Getting so tired of this!
Old Oct 26, 2003 | 12:29 PM
jleighZ's Avatar
jleighZ
Default Getting so tired of this!
I had a thread a month or so back about my car dying in while going into a major intersection, I took it to the dealer twice and they couldn't find anything wrong with it. Well it happened again this morning, and we nearly got hit by another car. I avoided it and got it pulled off on the side of the road and had to restart it, which is the first time I had to restart it with the key, usually it pop starts. I don't know what to do at this point. I am driving a car that could possibly seriously injure me or someone else. I can't sell it cause if this happened to someone else and they got hurt it could potentionaly come back on me. I want to get rid of this car so bad now, but not exactly sure how to go about Lemon Law procedures or a buy back from Nissan. I'm too broke right now to afford an attorney, so I just don't know what is going to happen. Should I contact my salesman, or go straight to NMUSA?
Old Oct 26, 2003 | 12:54 PM
vincenzobar's Avatar
vincenzobar
Manager of Nissan where purchased, don't leave till fixed. Be strong.
Old Oct 26, 2003 | 01:21 PM
maximadave's Avatar
maximadave
contact a lemon law attorney in your area. some work on a contingensy (sp?) basis.
Old Oct 27, 2003 | 07:03 AM
jleighZ's Avatar
jleighZ
The dealer I bought it from is in St. Louis, two hours away, so I'm trying to get as much done it down here as I can. They are looking at it as we speak though. I checked MO Lemon Laws, and it says 3+ times for the same problem can be considered a lemon, and this is the third time. Hopefully Nissan will buy it back and I can get out from under this.
Old Oct 27, 2003 | 08:34 AM
vincenzobar
good luck
Old Oct 27, 2003 | 12:08 PM
jleighZ's Avatar
jleighZ
They just called and said they ordered an air flow meter, so I dunno. They didn't even check my transmission either like I asked them to.
Old Oct 27, 2003 | 01:37 PM
maximadave's Avatar
maximadave
This may take some time, just be patient. Save all of your receipts from the dealer. Ask them about your tranny why it wasn't fixed. Don't accept, "We found nothing wrong with it" take them on a test drive if you have to.
Just look at my SHIFT_ tag line below my sig
Old Oct 27, 2003 | 01:38 PM
WashUJon's Avatar
WashUJon
File a complaint with the NHTSA and call NNA at 1-800-Nissan1.
Old Oct 27, 2003 | 02:26 PM
jleighZ's Avatar
jleighZ
Got the car back and they said that the air flow meter from my intake was messed up. I have an Injen intake, and they said this might be the culprit. THe guy called Nissan and they said oil from the aftermarket intakes get oil on the mafs, and they get messed up, but he said they are still not sure if this is what is wrong or not. BUt they are covering it, but he said if it keeps messing up they won't, so I'm going to go ahead and take that intake off.
I asked about my transmission problem, and they said that this is what caused that too, which I don't believe.
Old Oct 27, 2003 | 02:43 PM
alphared's Avatar
alphared
I was just about to ask if you had a CAI or popcharger installed. that does sound like the problem. if the MAF gets blocked or is not installed the car will stall. Happened to a whole lot of people who first installed the popcharger (thank god this never happened to me) Should have the MAF sensor replaced if its blocked with oil (the filter must've be soaked with oil for that to happen) Try it without the CAI and see if it stalls again, by the way did you ask them to check the ECU? it should've logged the stall and sensed where the problem was to cut the fuel.
Old Oct 27, 2003 | 03:15 PM
jleighZ's Avatar
jleighZ
Yeah they said no codes at all came up when they checked the ECU. THe guy told me at the dealership that the air flow sensor was missing, then I got a call from the service manager and he said that it had a tiny bit of oil on it, and he honestly didn't think it was the problem, but just to be on the safe side they are replacing it. I'm going to take the CAI off tomorrow and run it for awhile and see how it does.
Old Oct 27, 2003 | 03:33 PM
CottonWoodz's Avatar
CottonWoodz
They shouldnt do nothing for you.. Id send you on your way.
Old Oct 27, 2003 | 07:25 PM
alphared's Avatar
alphared
They said the MAF was missing? and that it had a bit of oil in it? If it's missing how can it have oil in it?
Make sure you reconnect the MAF sensor when you remove the CAI.
Old Oct 28, 2003 | 04:31 AM
jleighZ's Avatar
jleighZ
The MAF was connected, and I checked it last night and there is absolutely nothing on it.
jleighZ's Avatar
jleighZ
And why is that?
Old Oct 28, 2003 | 04:59 AM
Conceyted's Avatar
Conceyted
Originally posted by jleighZ
And why is that?
Maybe in some IDIOTIC way he was trying to say that you are lucky they are giving you a new MAF even though they are 99% sure it was caused by the CAI. Either way I hope that you get it fixed. I am having a problem like noone else on this board at the moment. At 5500+ rpms in second or third gears my check engine light throws and my slip and tcs off lights come on and the rpms start going up and down all over the place. I pulled the codes one time and it told me Crankshaft Position Sensor but since I have no ODBII computer I cant know for sure. They said the computer they have will tell them everything they need to know.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
