Rough idle
Old 03-17-2010, 04:18 PM
CS350Z86
CS350Z86's Avatar
Default Rough idle
Rough idle common in these cars?
Any easy fixes? Fliuds?
I know the a/c button boost sthe rpms that gets rid of it.
Old 03-17-2010, 05:06 PM
Chris@FsP
Vendor - Former Vendor
Chris@FsP's Avatar
What year is your car? What is the mileage? Do you have any check engine lights?
To answer your question, I do not believe a rough idle is inherent in these cars. There is usually something causing it. My old Z, a 2003 Track, always idled great when it was stock.
Old 03-17-2010, 07:03 PM
MTZ33
MTZ33's Avatar
Ma car idles a TINY bit rough.. barely noticeable but if u do notice it, its a little rough...
Old 03-17-2010, 07:34 PM
jonnylaw
jonnylaw's Avatar
check for vaccum leaks, dirty throttle body, dirty air filter, etc. Vaccum leaks have caused me idle problems in the past.
Old 03-17-2010, 07:47 PM
TheFarmer
TheFarmer's Avatar
Leave A/C on. WIN yo!!!
Old 03-17-2010, 11:14 PM
Jit13
Jit13's Avatar
I have this problem too with my 03 track. I replaced the spark plugs,pcv valve, belts, cleaned tb, cleaned air filter. its like it idles too low with a slight shake weird...
Old 03-18-2010, 05:05 AM
CS350Z86
CS350Z86's Avatar
Same exact thing. Rpms to low and causes the car to shake alittle. New intake, new belts, fluids. It's no big deal probably just curious. The a/c on fixes this problem tho.
Old 03-18-2010, 09:23 AM
PerfZ
PerfZ's Avatar
'03-'04 were known to skip a bit at idle, even brand new/bone stock. Mine did it and I just got used to it. After plenum space/Popcharger'headers/hi-flow cats it still skips a tiny bit but I've gotten used to it.
Old 03-18-2010, 09:39 AM
Zazz93
Zazz93's Avatar
Didn't the '04 and before have the ability to adjust the idle through CONSUL? Here is an idle stablization trick from JWT for "DECEL STABILITY". Check if this may apply to your issue.
http://www.jimwolftechnology.com/wol...BILITY_FIX.PDF
Desert Z (02-27-2019)
Old 03-28-2010, 05:39 PM
solar_n_orange
solar_n_orange's Avatar
Anyone experiencing the rough Idle also getting any CEL lights? I have a rough idle that is throwing a p0300 Random Multiple Misfire Code. Might try the JWT Decel trick for a cheap solution.
Old 03-28-2010, 07:17 PM
Zazz93
Zazz93's Avatar
Solar, With a random misfire code I would check the ignition system (plugs and coils). A lightly fowled up plug could have issues at idle and clear its self up further up the rev-range. Did this start after a recent mod?
Old 02-21-2013, 04:30 PM
solima
solima's Avatar
Ya I just put a catback and intake on and now it has a ruff idle maby its just because I can hear it better now with the exhaust.
Old 08-05-2013, 02:42 AM
CROWLEY
CROWLEY's Avatar
Default ANYONE ELSE HAVE THIS ISSUE. im lost with out a paddle
i hate the similar issue except my car is kinda puffing white smoke and idk why i baby the car is an 06 56k miles....the idle issue is almost noticeable under acceleration. my idle accorded to the digital read 650-712-860-625-550.. its never constant and i can feel while driving i have a engine light its P0420 o2 sensor crap.. but i really don't know what it is..its beginning to **** me off
Old 08-05-2013, 03:09 AM
oldschool350z
oldschool350z's Avatar
P0420 could be catalytic converter
Had the same code with an older car and it was the issue... Pretty expensive to replace unless you find aftermarket ones
Old 08-05-2013, 06:29 AM
Touge Z
Touge Z's Avatar
upgrade to high flow cats.
Old 11-30-2015, 02:47 AM
Ryan Lemons
Ryan Lemons's Avatar
Default Rough udle with cel light on bkinkcing as i drive
Ok been reading through the site I have yet to put on an obd2 engine code checker but my mph is like worse than a dodge pickup I am beginning to think it's my coil packs going bad and need reolacig along with spark plugs, it can't even do a burn out cause of the loss of power anyone can confirm my issue? New to this site and new to the cars I have , a 300 and 350.
Ryan Lemons
Mpg*
Old 11-30-2015, 03:58 AM
travlee
Master
travlee's Avatar
Received 9,059 Likes on 6,523 Posts
so now a triple post and thread hijack..... jeebus
https://my350z.com/forum/maintenance...-blinking.html
Old 12-25-2019, 02:22 PM
Gm_media
Gm_media's Avatar
Default Extreme rough idle
I i have a 2003 350z i just replaced vavke cover because they had a leak. I took upper and lower pleneum off to acess the valve covers and while it was apart also put in new coils and plugs then put everything back right and used all new gaskets even double and triple checked it go to start it and the idles so rough it sounds like it has a high performance cam but it wasnt doing it before any one know the issue?
Old 12-25-2019, 05:21 PM
813_350Z
813_350Z's Avatar
Go back and check it again. Check all gaskets and hoses. You have a vacuum leak somewhere.
Quick Reply: Rough idle
