Service Engine Soon blinks!
Old Mar 24, 2010 | 08:42 AM
zmego1999's Avatar
zmego1999
Default Service Engine Soon blinks!
I have a 2003 350z with a GReddy twin Turbo pushing 5 lbs of boost. The service engine soon light comes on every once in a while. I was told that it would do that every now and again. Now, it is blinking! It will not go away. What should I look at?
Old Mar 24, 2010 | 09:01 AM
tylerxfire's Avatar
tylerxfire
well def. dont start or drive it if it is blinking..i have never had an engine light come on being boosted so i dont see why it would be normal to throw the ses light whenever..
do u have cats on the car? is it running different when it is running..what were u doing when this happened
tylerxfire's Avatar
tylerxfire
go scan the code ..autozone or advanced auto does it for free
Old Mar 24, 2010 | 09:42 AM
c0ld29's Avatar
c0ld29
in the manual it says a blinking check engine light means a misfire
Old Mar 24, 2010 | 03:25 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Correct if it flashes it means bad misfire. Do NOT drive your boosted car with a misfire. Check you plugs one might have gone bad or a coil pack may have failed.
Old Mar 25, 2010 | 08:50 AM
tylerxfire's Avatar
tylerxfire
he just says the light is on...it would be very obvious if the car is misfiring so seems like he would have said that but idk..
op is the car misfiring? scan the code and see what it says for a start... i also would not rule out the cats if the car has cats on it if its not misfiring
Old Mar 28, 2010 | 10:23 AM
zmego1999's Avatar
zmego1999
I am new to turbo's. How would I know if it misfires? I don't think it is; however I am not sure. When I drove it last night, the light was not blinking.
Old Mar 28, 2010 | 12:38 PM
tylerxfire's Avatar
tylerxfire
having a misfire has nothing to do with being turbo..It is when all cylinders are not firing and it is missing a cylinder or two or 3 or whatever...u need to scan the code with a obd scanner...Does the car spit and sputter or run perfectly fine? sound any different?
Old Mar 28, 2010 | 12:40 PM
Jay'Z's Avatar
Jay'Z
Scan for the code or this is a useless thread.
Old Mar 28, 2010 | 01:14 PM
Tomek350Z's Avatar
Tomek350Z
generally when it blinks its probably damaged cats....but check the code to make sure
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
