350z twin turbo starts and shuts off
Old Apr 5, 2010 | 09:03 PM
zmego1999's Avatar
zmego1999
Default 350z twin turbo starts and shuts off
I have a 2003 GReddy Twin Turbo Z. It runs fine at 5 lbs of boost. It was boosted in August, and I haven't had problems with it really.
Today I drove it from home to the grocery store, about 2 miles. Then I drove it to work, another 10 miles or so. I try and leave work, and the car starts, and then dies. It does it again, turns on, then dies right away.
I figure it isn't getting gas. So I start the car with my foot on the gas peddle. It started up, but very jerky. It has gas in it, right above a quarter tank. When I am at a light I have to leave it in neutral and give it gas. What is wrong with it? ANy ideas? I don't want to pay a dealership $90.00 an hour to tell me it's something when this could be something I can fix on my own.
HELP!
Old Apr 5, 2010 | 09:15 PM
HDPDZO6's Avatar
HDPDZO6
HELP!
Start looking for loose fittings. My Vette did something similar (didn't die on me, but was very jerky). Ended up being a loose MAF connection.
Old Apr 6, 2010 | 01:25 AM
duro78's Avatar
duro78
Once you go fi I really wouldnt take it to the dealership I wouldnt go anyway but you know
Old Apr 6, 2010 | 05:13 AM
zmego1999's Avatar
zmego1999
Well, I am taking it to an Auto Parts store today to see if it's throwing a code. Then I will go from there.
Old Apr 6, 2010 | 05:17 AM
fairladyinit's Avatar
fairladyinit
Sounds like you have a vacuum leak somewhere. Check all your pipes.
Old Apr 6, 2010 | 05:19 AM
RandomHer0's Avatar
RandomHer0
^^ Thats what I was thinking...
Check all your hoses/fittings
Old Apr 6, 2010 | 05:54 AM
zmego1999's Avatar
zmego1999
It's drivable. I need to keep my foot on the gas to start it and at idle. It is the TPS sensor. How easy is that to replace?
Old Apr 6, 2010 | 07:08 PM
nismo1234's Avatar
nismo1234
Default problem
it could be a vacuum leak but also check your air flow sensor but first check if the ecu is throwing codes. good luck
Old Apr 6, 2010 | 08:18 PM
redman333's Avatar
redman333
I'm thinking vacuum leak. Wouldn't a faulty maf have problems through out the rev not just idle. The tps sounds like that could be it also but once you get past the faulty part of the tps then it should run like normal.
Old Apr 8, 2010 | 04:52 AM
infamous350's Avatar
infamous350
i had this problem i changed my plugs and cleaned my MAF gave half *** cleaning to the throttle body and wiped it down with a rag. now my car starts up so fast and idles smooth and nice
etkms
Jun 19, 2022 06:30 PM
gc350z03
Oct 28, 2016 05:00 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Darkspy
Sep 7, 2015 09:09 PM
