Need Fuel Injector Help Please!!
Old Apr 17, 2010 | 06:17 PM
WestieQ's Avatar
WestieQ
Default Need Fuel Injector Help Please!!
I have been trying for weeks to get information on the fuel injectors for my Z and I can't seen to get the data anywhere. I've called Bosch customer service, Bosch Motor sports, and even their administrative office in IL and still no answer.
Here's what I need: Bosch Fuel Injector, Part No. 0280158117
Dead Time
Battery Voltage Offset Table
Close and Open Time
I really need this info to be able to get my Z running properly (2004 Touring 6spd. Turbo Charged). In fact, I am offering a $25 reward to whoever gets me the correct info! Please trust me on this, I'm serious. I will mail a money order to whoever can get this data correctly!
Thanks all for the help.
you can e-mail me at "larjoyquig@yahoo.com" or "lgiglio@cusa.canon.com"
Larry
Old Apr 18, 2010 | 07:59 AM
WestieQ's Avatar
WestieQ
Default Moved?
My question about fuel injectors was moved to some other area. Does anyone check this location?
Old Apr 23, 2010 | 01:07 AM
Synjn's Avatar
Synjn
Dead Time
Close and Open Time
Larry
Got it!
http://www.fiveomotorsport.com/impor...s/?itemid=1208
njector type: 6-hole disc, EV14
Flow pattern: narrow cone
Tested Flow Rates:
500cc/min at 3 BAR
540cc/min at 3.5 BAR
580cc/min at 4 BAR
Resistance: 12.8-14.5 Ohms
Voltage: 8-15 Volts, Nominal 13.5 Volts
Pressure: Min. 36 PSI (2.5 bar), Max. 130 PSI (9 bar)
Dead Time: 0.7ms at 14 volts
Surface finish: Black composite
All Viton o-rings Included for installation.
Import 4 and 6 cylinder cars.
