New owner...2 questions??
Old Apr 21, 2010 | 06:22 PM
Indy08Z's Avatar
Indy08Z
Default New owner...2 questions??
2008 w/6k all stock
1. I turned down my radio last night while driving to just listen to the sounds my Z makes. When I shift gears, it makes like a low popping noise. The noise comes from the shifter, not like it's popping into gears. The noise sounds like the top of a baby jar when you push in on it...but not as loud. If the radio is down, and the windows are down you can barely hear it. Is this normal & can someone verify the noise?
2. If I rev the engine up, when the rpm's are coming back down, it gets to 1500 rpm's then slowly goes to the idle rpm's. Is this normal & can someone verify?
Thanks in advanced.
Old Apr 23, 2010 | 12:07 AM
Synjn's Avatar
Synjn
Is it popping when you depress the clutch or release it. Or when you shift?
How long does it stay at 1500?
Old Apr 23, 2010 | 07:15 PM
Indy08Z's Avatar
Indy08Z
No, it makes the baby jar pop sound (but not as loud as the baby jar) from the shifter when I shift into gears. I think it might be normal, just need someone to confirm. Z is all stock. It doesn't jerk or feel weird, just a real faint baby jar pop.
If I rev it up, when the rpm's are falling back down to idle, it stops at 1500 rpm's then slowly drops to it's idle between 650-750 rpm's. I think this also might be normal as well.
Was seeing if someone else could confirm these for me.
Old Apr 23, 2010 | 11:22 PM
silverbullet_Z's Avatar
silverbullet_Z
Normal for the rpm to do that, as for the popping sound I would have to hear it. I dont ever recall hearing a popping sound in my Z..
Old Apr 24, 2010 | 07:13 PM
Indy08Z's Avatar
Indy08Z
Ok...so I decided to try turning everything down again, and after doing some more research, I think I know what's wrong. I was wrong about the popping sound coming from shifter, it's coming from the clutch when I depress it. Also, every day that I drive it, it becomes harder and harder to shift into 2nd, and from 2nd to 3rd. Do you think replacing the syncros in the transmission would fix this problem.
I guess, regardless, it's under warranty and I can just take it in. I have an appointment on Tuesday, just hoping nothing happens between now and then.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
