Alternator fuse keeps blowing... help!
Old Apr 23, 2010 | 12:57 PM
wtk's Avatar
wtk
Default Alternator fuse keeps blowing... help!
So today, my battery light and brake light came on while I was driving down the hwy. The voltage was reading about 1v higher than normal. I checked the fuse under the hood and it was blown, so I replaced it and everything went back to normal. I thought that was problem solved, but it just blew again after 20 minutes of driving.
What could me problem be?? ...any help would be greatly appreciated!!!
Thanks!
-William-
Old Apr 23, 2010 | 04:55 PM
wtk's Avatar
wtk
Bump for some help...
a little back ground info that might help... I have no after market electronics other than a UTEC and gauges that have been in there for years. I do have a vented hood, maybe water could have caused damage to the alternator? It is blowing fuses immediately now... something is either touching or the alternator is no good, I suppose?...
Old Apr 23, 2010 | 07:01 PM
wtk's Avatar
wtk
...one more thing, the fuse blows without a key even in the ignition. That = short right?
Old Apr 24, 2010 | 10:39 AM
wtk's Avatar
wtk
...well just in case someone else has this problem...
I pulled the alternator, it checked out just fine. So, I started tracing the alternator lines, the positive one was very close to a pipe running off the passenger side turbo. It looked to have melted the wire in a tiny spot. I electrical taped it up (because only 1 wire looked to be exposed) and then heat wrapped it. So far, no more blown fuses. I'm really praying it stays that way...
350Z Project X
Oct 17, 2015 05:16 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
