350Z Fuse Layout
Old Apr 24, 2010 | 10:53 AM
Got_Wood's Avatar
Got_Wood
Default 350Z Fuse Layout
My rear defroster is gronked. I'm trying to check the fuse, but the manual doesn't have the fuse layouts. The snap-off panel has the interior fuse layout, but the rear defroster isn't mentioned.
The under the hood fuses don't have any layout.
Help!
Is there a guide to the layout of 350Z fuses?
PS - I have a 2003
Old Apr 24, 2010 | 11:22 AM
The factory service manual has complete fuse information. Available for free on the internets.
Old Apr 24, 2010 | 11:24 AM
xzotklr's Avatar
xzotklr
Check to make sure none of the wire on the glass is not broken. If so it would noy work.
Old Apr 24, 2010 | 11:26 AM
350junkie's Avatar
350junkie
the fuses under the hood do have a lay-out. It's on top of the black lid that you pull off to access the fuses.
and you can download the appropriate service manual here:
http://www.nicoclub.com/FSM/350Z/coupe/2003/gw.pdf
it lists all the fuses that are linked in that system and where they are.
Old Apr 24, 2010 | 11:39 AM
DavesZ#3's Avatar
DavesZ#3
All the FSM has is wiring diagrams and fuse numbers, you'll have to trace it down and figure it out yourself.
The diagrams inside the covers at the kick panel and under the hood are the best way to go as they have descriptions for each.
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
350Z Project X
Oct 17, 2015 05:16 PM
codek
Sep 28, 2015 03:03 AM
