Drivers door connector scheme
Hello dears, I wanted to clean my driver's side window motor and I have broken my connector. All cables are out of it. Do you please have the scheme of which wire should go were?
Thank you a lot!!
Thank you a lot!!
Thank you, got it. I just don't know if my motor is dying or if there is not good contact on the connector. I cleaned the motor but it was clean. I decided to clean it because my window didn't want to roll up few times before and today when I opend the door, and wanted to close it, I heard some very bad noise. It was my window to the roof. I noticed that my window is not going down 2 cm when the door is opened. Also the switch was always clicking, but no sign from the window to go up or down. I will try to connect it tomorrow as it's shown in the manual and we'll see. But I noticed that when I had the panel with switches in my hand out of the door and moved with it from left to the right, I could hear the clicking as I would push the switch.
Thank you for now, will come back tomorrow.
Last edited by uhlo666; May 23, 2010 at 11:44 AM. Reason: found resolution as adviced
Hello all, so I'm here again. The same problem again. Yesterday at night when I went home it could be 13 centigrades and my window won't roll down. I gave a bang with my hand to the door and the window rolled down for a while. Then I closed the window and it didn't work anymore. Today the sun is shining on the door and it's 25 centigrades, and when I opened the door, the window automatically went down 1cm or so, as it could. So I think the problem won't be in the motor, but there will be some bad contact in the cable. Maybe it's between the door and car.
Anyone had the same problem? My Z is 2005 and it has 107 000 km (66 500 miles)
nope, its the motor, you can get by for a while banging on the side of the door to get it to work, but eventually you'll have to bite the bullet and replace the window motor.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
