P0301 Misfire @ #1
Old May 24, 2010 | 02:40 PM
BigA's Avatar
BigA
Default P0301 Misfire @ #1
I scanned my Z and got this code. Is there a common problem for the Z's? My 2003 just reached 84K, and only has a Nismo Cold Air. Hope to get some good tips..
Old May 24, 2010 | 02:45 PM
cdoxp800's Avatar
cdoxp800
Info can be found here
http://www.nissanhelp.com/diy/obd_codes/p0301-p0308.htm
Old May 25, 2010 | 08:51 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Spark plugs are the most common cause there. Could be any number of things that cause a miss though, bad injector, injector not getting power or ground etc. Did something else happen when this code started coming up or did it just start happening?
Old May 25, 2010 | 07:08 PM
BigA's Avatar
BigA
Default P0301
I think its a bad coil-pack. Priced it out already for $113 from Nissan. Im gonna try this first cause the spark plugs are new still.
Old May 2, 2017 | 10:14 AM
Extreme Dimensions's Avatar
Extreme Dimensions
Here is the FULL list of problems associated with a misfire code
Faulty spark plug
Clogged or faulty fuel injector
Faulty ignition coil
Fuel injector harness is open or shorted
Fuel injector circuit poor electrical connection
Ignition coil harness is open or shorted Ignition coil circuit poor electrical connection Insufficient cylinder compression Incorrect fuel pressure Intake air leak
Good luck on the repair! Anything past a coil I would take it in and call it damage control.
Old May 2, 2017 | 11:21 AM
jhc's Avatar
jhc
General & Tech Moderator
Good tips, Zombie thred tho.
lowtempo
Jun 25, 2025 11:47 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
disturbed2483
Aug 5, 2009 05:54 PM
sentry65
Jan 14, 2005 08:51 PM
350Zzzz
Dec 16, 2003 08:12 PM
