ac blowing warm
Old Jun 2, 2010 | 04:50 PM
350sexZ's Avatar
350sexZ
Default ac blowing warm
Ac blowing warm while stopped or idling. I checked the freon that's good and the clutch is spinning. When I drive it cools like a champ just won't when I stop. Any ideas what it might be thanks
Old Jun 2, 2010 | 04:57 PM
JCat's Avatar
JCat
Make sure both radiator fans are running when the AC is on.
Nissan extended the warranty on your two radiator fans to 84 months because they fail prematurely. If one or both of them fail, the refrigerant in the AC system does not get cooled enough when it passes through the evaporator.
This happened to me. I'm curious if you have the same problem?
Old Jun 2, 2010 | 06:14 PM
SoarVigor's Avatar
SoarVigor
^^ This is probably it.
Old Jun 2, 2010 | 10:41 PM
winchman's Avatar
winchman
See: https://my350z.com/forum/maintenance...problem-2.html
Sounds like same issue.
Old Jun 4, 2010 | 09:23 AM
350sexZ's Avatar
350sexZ
Ok thanks guys ill check that out
MAsSIVrOOM
Oct 20, 2023 10:50 AM
apex locator
Jul 23, 2021 02:27 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
