I have a little smoke coming from the exhaust
Old Jul 18, 2010 | 08:40 PM
dozer808's Avatar
dozer808
Default I have a little smoke coming from the exhaust
To get down to it I ran the car the other day very hard I think I went to high up in the RPM’s like in the 7000 range and got some smoke when I let off. Pulled over and checked it out at idle the car has a little smoke from the exhaust and there is a ticking or knocking noise from the heads on the drivers side. It sounded like all pistons was firing so I drove it. Since I was way out I had to limp the car home at about 55-60 MPH. No smoke when the car is running higher then idle or at least none that I could see.
What could be the problem? Do I need new heads or could there be a hole in a piston? Do I need new rings? Could I be getting blow-by or what?
Need some help so I take the correct steps to fix this problem.
Built short block
Stock heads
Turbonetics ST kit 14 PSI
Old Jul 18, 2010 | 08:43 PM
eltness350's Avatar
eltness350
The Untouchable
need more/better info...what color is the smoke and how much ? 7k on stock heads....
Old Jul 18, 2010 | 08:58 PM
dozer808's Avatar
dozer808
Yeah I should have put that. The smoke has a blue tint to it.
Old Jul 19, 2010 | 07:22 PM
dozer808's Avatar
dozer808
Nobody knows anything about the big stuff. Thats cool I'll make it.
Thanks.
Obadabot
Jun 18, 2023 11:31 PM
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
