do any of the forum sponsors sell maintenance kits?
i have a 2004 enthusiast.. with 58k on the clock
i want to do the 60k service...
engine oil and filter change
transmission fluid drain/refill
rear differential fluid drain/refill
Engine air filter
Cabin filter
belts
any forum sponsors sell a package? Or should I go to the store buy these parts individually?
I found a lot of good information on the site as far as when to do the maintenance, but can someone list the oil weights for 1) engine oil, 2) tranny oil, 3) rear diff? thanks
Engine air filter
Cabin filter
belts
Engine air filter
Cabin filter
belts
Engine air filter
Cabin filter
belts
Check your local places (Autozone, OReilly, Pepboys, etc.), they are always having sales on oil and filters. If you don't have a preference, take the first one that comes along, otherwise wait for your personal fave to go on sale.
You don't see Trans and Diff lubes on sale that often so your best bet is to shop around locally.
Engine air filter - either get a OEM filter or a good quality name-brand, anything except Fram.
The Z doesn't have a cabin air filter.
I get belts from the dealer. High quality, guaranteed to fit, no squeeling.
Some of that you can order from the online places like MyNismo (Performance), Courtesy Nissan, etc.
Your owners manual lists all the proper weights and quantity for fluids. There's also a Maintenance sticky at the top of the forum that has links to a bunch of DIY threads. Check it out for fluid recommendations.
The biggest problem with a "kit" is it conflicts with so many personal preferences. Everybody has their favorite motor oil, air filter, lubes. Any kit put together probably wouldn't sell for that reason alone.
In regards to the weights...I see it in the user's manual. But given that it was written in 03/04, I was wondering if Nissan announced any changes and recommended the use of different products/weights? How do I know which differential oil to use? Some have additives, some do not.
Although written years ago, the engine was designed for a certain grade of oil and that is what should still be used.
The newer 350s came with synthetic oil in the trans and diff. That is the generally accepted practice around here too - when you change diff and trans, go with a synthetic.
The threads I referenced (DIYs on changing trans and diff) have suggestions on the brands, weights and amounts needed. It can be a little confusing picking one. Diff requires GL-5, trans requires GL-4. IIRC, Royal Purple is both GL-4 and GL-5 compatible without the harmful GL-5 additives that our trans doesn't like. So there is a little research required before you blindly pick lubes. Also, the weights aren't always available so you'll see some mixing of two weights to make the required one.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
