window wont auto down when open door
Old Aug 7, 2010 | 07:30 AM
ppanzil88's Avatar
ppanzil88
Default window wont auto down when open door
hi guys
i need help.. my driver side window wont go down when i open my door
window goes down and up fine with no problems what so ever
but when i just open and close the door it wont go down and up for a tiny bit.
passenger side is fine but driver side is causing this..
can any one help?
thank you
Old Aug 7, 2010 | 09:48 AM
DemitriHKS's Avatar
DemitriHKS
I'd like to know as well. Some times my passenger window actually stays too high and hits the border. If someones not careful they will smash my window, scares the **** out of when I see it happen. Mine is the passenger only
Old Aug 7, 2010 | 10:13 AM
diablox1's Avatar
diablox1
search for the window reset procedure
Old Aug 7, 2010 | 10:15 AM
cdoxp800's Avatar
cdoxp800
NTB04-089 Window Regulator Motor Reset Procedure
Old Aug 7, 2010 | 09:01 PM
RandyK1's Avatar
RandyK1
The button (switch) that the door hits when closed might have gone bad.
Old Aug 7, 2010 | 10:40 PM
ppanzil88's Avatar
ppanzil88
ah... only if you have left this this comment little bit earlier!!
i opend everything and try and try resetting the window motor and it still didnt work and when i was about to give up.. i found out my door switch was dangling around...
the bolt that holds the switch got off and my switch was just off the door trim and not working right..after put the switch with new screw, it works fine now. but i learned how to reset the window motor so it was too bad i guess lol.
THANK YOU GUYS for all the replies
Old Aug 9, 2010 | 12:13 PM
ANIBAL's Avatar
ANIBAL
U do know that u can get ur window down by holding the remote botton for a few seconds and up with ur key tours the right?
Hope I could be of any help!
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
