Seats won't move forward and back, help!
Old Aug 8, 2010 | 01:41 PM
Adon's Avatar
Adon
Default Seats won't move forward and back, help!
I know moving the seats around while the car is off will drain the battery after a few minutes to the point where you won't be able to move the seats around anymore and have to turn the car on.
But once the car is back on they should work after from personal experience.
Now the car is on and the seats will only recline, so the forward and backward switch doesn't do anything, the seats refuse to move, and to make things more difficult the seats are all the way up to the front because I was working in the back seats.
the idea was to take the 4 bolts out holding the seats in and disconnect the wiring harness maybe somehow reset the seat motors, but that's impossible now with the seats pushed all the way up, I'm unable to access the two front bolts.
__________________
Old Aug 8, 2010 | 02:04 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I take it you have a G35.
Old Aug 8, 2010 | 02:12 PM
Adon's Avatar
Adon
yea I do, a coupe...
also wanna add more info to the list now..... few other things aren't working either, like the sunroof won't open and close, the interior trunk light doesnt turn on neither do the lights on the bottom of the door (step lights) as well as the mirror lights don't turn on once I flip open the mirror cover......
we've checked a bunch of fuses, all 3 fuse boxes, and can't find any blown fuses.
Old Aug 8, 2010 | 02:14 PM
AdvanZ33's Avatar
AdvanZ33
Probably not a fuse issue with that many outages. I had gauges, odometer, stereo, etc. go out and it was my a/c module.
Old Aug 8, 2010 | 02:41 PM
Adon's Avatar
Adon
ok the sunroof is back working, everything else still not.....
can you guys give me more info on the battery reset procedure, how long does it take exactly for the "brain" of the car to reset itself.
meaning how long do I have to keep the battery unhooked for everything to go back to normal.
Old Aug 8, 2010 | 03:33 PM
duro78's Avatar
duro78
Is the motor attempting to move the seat? Check the rails there can be something lodged in there preventing it from sliding has happened to me before
Old Aug 8, 2010 | 04:00 PM
Adon's Avatar
Adon
no the motor won't even come on. So it's another issue, something to do with electrical.
ok so I tried disconnecting the driver side motor and then reconnecting it, and now it won't even recline !!!
so nothing works on the drivers side currently, before the recline motor was working at least.
Old Aug 8, 2010 | 06:12 PM
Adon's Avatar
Adon
FIXED:
BLOWN FCKIN FUSE, FCK what a headache
Old Oct 11, 2010 | 04:54 PM
alwx2's Avatar
alwx2
2003 Roadster. Purchased last year. I was vacuming behind driver seat.
Seat now goes back and forth - no problem
Would incline foward, not back. Now in forward most position. Can't drive it.
Took out the seat taking it to dealer tomorrow morning.
Glad I got warranty
Old Oct 13, 2010 | 05:41 AM
Mapleleaf's Avatar
Mapleleaf
Glad I got warranty
Happened to me about 2 months ago , I had to replace the seat switch
Old May 23, 2011 | 03:47 PM
SQBassHead's Avatar
SQBassHead
I know this is an old *** thread but I need to know where that fuse is op
My passenger seat just took a crap I already tried the cleaner thing and it still won't work
Help plz
Old May 23, 2011 | 03:48 PM
SQBassHead's Avatar
SQBassHead
Also is there a way I can tell if i need a new switch. Or motor?
Old Jan 31, 2013 | 07:54 AM
acekid187's Avatar
acekid187
I'm with SQBassHead. I need the same answer. My driver side seat won't go toward moves back and reclines back just fine. Recline forward after messing with for a while. But won't move forward at all
Old Jan 31, 2013 | 08:16 AM
Mapleleaf's Avatar
Mapleleaf
Had the same problem I had to replace the seat switch
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
