70 mph
Aug 14, 2010 | 03:18 PM
70 mph
im having an extreme wobble in my back right at 70 mph. someone help me figure out if its suspension wheel balance or etc...
Aug 14, 2010 | 03:25 PM
Aug 14, 2010 | 03:28 PM
nope, my car drives and feels prefectly number but if its under a load or even in neutral between say 69 and 73mph just hardcor vibration and wobble
Aug 14, 2010 | 03:29 PM
stock or aftermarket wheels?
Aug 14, 2010 | 03:35 PM
Tire out of balance
Wheel not centered on hub
Tire worn, cupped
Tire tread separation
Aug 14, 2010 | 05:19 PM
its possible that you're u-joint on your driveshaft may be beginning to seize up. check it out, ive had similar issues and that's been the problem.
Aug 14, 2010 | 05:31 PM
stock rims, thanks for the info gonna be doin some research
Aug 14, 2010 | 07:20 PM
Aug 14, 2010 | 08:07 PM
Year? Mileage?
Lowered? That would cause increased wear on the rear axle CV joints.
Aug 14, 2010 | 09:26 PM
Surprised that you can pinpoint the problem to rear passenger side. Now you now exactly where to go for a solution.
Aug 14, 2010 | 09:44 PM
Aug 15, 2010 | 03:01 AM
Thinking about it more, 70mph sounds like a tire out of balance or something else wrong with the tire.
I had a Mustang once that swayed from side to side in the rear at certain speeds because of a failure of the belt under the tread, according to the tire dealer. It was replaced under warranty, and the problem went away. Not long after that, the car went away, too.
Aug 15, 2010 | 04:12 AM
Specific MPH range usually suggests balance. I'd go there first.
Aug 15, 2010 | 04:43 PM
Aug 15, 2010 | 05:38 PM
Aug 15, 2010 | 06:19 PM
Tire/wheel balence, or damaged tire.
I have had plenty of beaters with cheap tires to know.
Aug 17, 2010 | 04:06 PM
make sure to check your wheel bearings too
TrboMike
North East
Sep 28, 2015 06:36 PM
CrowzRSA
Sep 21, 2015 04:00 PM
FromGtoZ
Sep 20, 2015 03:41 PM
T'S 350Z
Event Photos
13
Sep 17, 2015 12:55 AM
fst100
North East
Sep 8, 2015 11:37 AM
