A/C dies after 5500 RPMs
Old Aug 26, 2010 | 06:38 PM
rk40k's Avatar
rk40k
Default A/C dies after 5500 RPMs
I have an 04 350z, the a/c runs cold until I take the car past 5500 rpms at that point the air goes hot until I turn the car off. Once I restart the car the a/c goes back to normal. Does anyone know what is causing this and how to fix it?
Thanks
Old Aug 26, 2010 | 07:04 PM
03threefiftyz's Avatar
03threefiftyz
Simple answer.....turn the ac off before revving that high....then turn it back on.
Old Aug 27, 2010 | 05:59 AM
rk40k's Avatar
rk40k
Yeah, that doesn't work
Old Aug 27, 2010 | 06:12 AM
kacz07's Avatar
kacz07
Hmm... some carmakers have a feature that turns off the AC to reduce parastic power loss. The logic behind this is sound. If you're at WOT, you're making an emergency maneuver (merging, etc) and need all the power you can get.
It's possible the sensor or ECU is flawed. Are you aftermarket tuned?
Old Aug 27, 2010 | 06:22 AM
rk40k's Avatar
rk40k
The car is stock. I read through the troubleshooting section in the service manuel and I couldn't find anything that would give me any clues.
Old Aug 27, 2010 | 08:52 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Compressor shuts down at WOT. Sounds pretty normal unless you are driving under normal conditions for a few minutes afterwards and it still blows hot.
Old Aug 27, 2010 | 09:11 AM
rk40k's Avatar
rk40k
It continues to blow hot until the car is shut off and restarted.
Old Aug 27, 2010 | 10:10 AM
Brett@AwesomeZ
Hmm, then that certainly isn't normal. Does the compressor not come on at all after getting on it? Does it matter what position the A/C switch is on? (auto or not?)
Old Aug 27, 2010 | 10:34 AM
rk40k's Avatar
rk40k
The compressor doesn't come back on and I have tried it in all the different a/c settings.
Old Aug 27, 2010 | 11:09 AM
Brett@AwesomeZ
You may have a problem with your A/C controller ( auto amp ). I hate to say this but it would be best to get it to a dealer or someone that has a Consult diagnostic tool. The ECU, BCM and A/C controller all share various data that decides when the compressor is to be switched on, the the ECU switches it on via the IPDM. The BCM and A/C amp both have their own diagnostic modes that can be accessed with Consult and you basically need to find out if it is an input or output problem.
Old Aug 27, 2010 | 11:11 AM
rk40k's Avatar
rk40k
Alright, Thanks Brett
Old Aug 27, 2010 | 11:12 AM
Brett@AwesomeZ
No sweat man. Hope it works out. Let us know what you find, cuz now I'm curious.
Old Sep 2, 2010 | 11:06 AM
Zazz93's Avatar
Zazz93
It been said before but here is the FSM's description of the AC operation.
SYSTEM DESCRIPTION
This system improves engine operation when the air conditioner is used.
Under the following conditions, the air conditioner is turned OFF.
  • When the accelerator pedal is fully depressed.
  • When cranking the engine.
  • At high engine speeds.
  • When the engine coolant temperature becomes excessively high.
  • When operating power steering during low engine speed or low vehicle speed.
  • When engine speed is excessively low.
  • When refrigerant pressure is excessively low or high.
Old Sep 2, 2010 | 11:14 AM
can'tZme's Avatar
can'tZme
^My AC shuts off at low engine speed (RPM's) when I push the clutch in but I can't figure out why it drops so low every time
etkms
Jun 19, 2022 06:30 PM
liqalu04
Jan 2, 2022 12:58 PM
Justin100
Nov 29, 2015 03:58 PM
