My Z totally Doesn't do well in traffic.
Old Sep 14, 2010 | 12:32 PM
zen350z's Avatar
zen350z
Im 100% sure its your fan that isnt coming on that needs to be replaced easy way to check is let it get above normal operating temp turn on the ac so that fan kicks on and if your temps go down get that other fan replaced Asap.
Old Sep 14, 2010 | 12:35 PM
06blueZ's Avatar
06blueZ
yep looks like you need new fans...
marques1's Avatar
marques1
I believe they are suppose to kick on at the same time. That is probably your issue.
Old Sep 14, 2010 | 01:01 PM
Ghalleo's Avatar
Ghalleo
By now im sure u prolly know that im not much of a tech guy. Do the fans come seperately or would I have to buy the who fan assembly?
Old Sep 14, 2010 | 01:45 PM
06blueZ's Avatar
06blueZ
I think they come together with the shroud, but if not I would go ahead and replace both. If one wore out its logical that the other might not be far behind...
Old Sep 14, 2010 | 02:08 PM
zen350z's Avatar
zen350z
you can just replace the motor of the fan. Just make sure you take the old one in with you so you can match them up so they dont give you the wrong side.
http://www.autozone.com/autozone/par.../N-jklthZ9pd9y
Old Sep 14, 2010 | 03:25 PM
Zazz93's Avatar
Zazz93
Before you start replacing them, get under the car and pull the lower shield and figure out if all the connectors are connected tightly. Our cars have varying fan speeds and will begin to overheat at idle after only a few minutes. If you ever hear the fan speed kick up at idle (first level of fan is fine, second level is bad) know the temps are getting out of hand. This is generally a sign of air in the system. Check your reservoir, if it is out of coolant you've probably have a problem with air in the system and low coolant levels. If the levels are all good and the connectors look fine go ahead and replace the broken fan/assembly.
Old Sep 16, 2010 | 11:17 AM
POWUH's Avatar
POWUH
I had a similiar problem , I ended up bleeding the coolant from the radiator and it went back to normal. I would do this before deciding on changing the fans.
Old Sep 16, 2010 | 10:32 PM
WhiteNoiz's Avatar
WhiteNoiz
thanks for that info, I will remember that if needed in the future
Old Oct 29, 2010 | 02:45 PM
Ghalleo's Avatar
Ghalleo
Hey Guys, I finally got my car out of the SHop. The cluprit was the Fans. I got them replaced now my car doesn't overheat anymore. IT feel soo great . Thanks FOr all the helpful info guys
Old Oct 30, 2010 | 05:57 PM
zen350z's Avatar
zen350z
No problem glad to hear your back on the road.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Juztin
Nov 22, 2015 07:03 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Depravity
Oct 1, 2015 04:49 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
