problems with the AC
Old Sep 20, 2010 | 01:58 PM
usa_alex's Avatar
usa_alex
Default problems with the AC
the AC has not been used for about 2 years-- i put a new condenser in it and the line that goes from the pump to condenser
today i tried to charge my AC system
i turn the AC- ON
turn the blower to hi speed
and open the bottle to start recharging it
as soon as the system starts taking refrigerant in the clutch engages and the pump starts working
so far so good
the pump makes an horrible noise just like a bearing without lubricant and no cold air inside
there are no leaks and the system took enough refrigerant in
any help is appreciated
thanks
Old Sep 21, 2010 | 09:51 AM
usa_alex's Avatar
usa_alex
nobody can help???
Old Sep 21, 2010 | 10:04 AM
vthao's Avatar
vthao
You already found the problem. AC pumps making horrible noises aren't normal. Either the pump was dry of lubricant and burned out, or the clutch froze.
Old Jan 21, 2011 | 03:24 PM
nel123's Avatar
nel123
Also i will like to know if somebody knows how to change the DriveAlign Premium OE Idler Pulley of the 350z i think when the belt broke it broke the drie align idler pulley???
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
