problem with my Z
Old Jan 17, 2011 | 06:52 PM
spidi13's Avatar
spidi13
Default problem with my Z
Hi guys,
I have recurring problem with my Z 2003 since my purchase. When i want have some fun with, my engine block between 3000-4000 rpm even if i put the pedal into a carpet. The RPM block and it rises slowly.
Anyone have idea?
I check with Nissan garage and he detect no problem. I change my MAF sensor but the engine block less often than before. No sensor emit no code.
I think put OEM intake because i have a injen intake on my engine. And maybe TB change because one guy told me changed TB and this stopped problem.But it's true????
thanks,
Old Jan 17, 2011 | 06:59 PM
z2g's Avatar
z2g
Possible weak fuel pump?
Old Jan 17, 2011 | 09:52 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Jan 20, 2011 | 03:11 PM
JAM3Z's Avatar
JAM3Z
Phenom
What????
Old Jan 20, 2011 | 03:33 PM
spidi13's Avatar
spidi13
hahah
Sorry for my english, i'm really bad.
It's just , sometimes my Z run like on the idle even if i crush the gas pedal. Must often between 3000-4000 rpm. Suddendly, it react maybe after 10 seconds.
I change MAf and i have a injen short ram intake but i think my Z don't like P-Flow. I change my filter for the OEM Box and the problem decreased by 20%maybe.
This problem is reccuring.
Old Jan 21, 2011 | 05:19 AM
acheung456's Avatar
acheung456
Originally Posted by spidi13
hahah
What is P-Flow? If you're losing response when you crush the pedal you probably have a fuel delivery problem. But if it's stuttering, and response is shaky and instable it's probably an intake problem. I'm sure the Injen intake isn't causing it.
Do some routine maintenance: Check your plugs, clean your TB and IM(if you have time, don't forget to replace gaskets).
At idle, can you rev up to 4000 no problem? or does the engine just not respond at all?
Old Jan 21, 2011 | 08:42 AM
spidi13's Avatar
spidi13
K i can do this for maintenance but for your question. Yes i can rev up to 4000 rpm at idle with no problem. The problem happens when I ride with my Z. It cuts almost always more frequently when it is wet. That may be unrelated to my problem!
This is when I go for a walk and I want to have fun. I weigh the gas pedal and it responds to the bottom until 3000-4000 rpm where it looks like he works at idle (no power). Myself I already beat by a civic stock on the 1 / 4 mile.
Sometimes it never blocks and I'm going to have fun with my Z all day. It's really weird. Nissan did not find anything in 3 full scans.
Old Jan 21, 2011 | 09:32 AM
DaveJackson's Avatar
DaveJackson
Master
Vous etes need to use some sort of le Francais to l'Anglais translation program... S'il vous plaits.
Je suis can't understand what the (seal en francais) you're talking about.
Old Jan 21, 2011 | 11:57 AM
Zazz93's Avatar
Zazz93
For hesitation issues try the following,
-First do all of the relearn procedures, just in case someone played with the throttle body.
-Check the plugs, may not be a bad plug but they may give you a hint which cylinder is having a problem (also could diagnose to a problem coil).
-Check fuel pressure
Old Jan 21, 2011 | 06:45 PM
spidi13's Avatar
spidi13
Sorry for my English but thank you nevertheless to have to try to understand my problem.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
