My car just not like the cold???
Old Oct 6, 2010 | 07:04 AM
slo_latino's Avatar
slo_latino
Default My car just not like the cold???
hola! im a little confused on what my car has been doing lately...the last three times i have started the car in the morning when it has been kinda cold out (about 55F) i warm up the car, then about a mile later down the road all my dash lights come on...like e brake, seat belt, traction control, ect...kinda scares me because i can take my seat belt off and re connect it it wont turn the light off. and also when i pull the e brake up and back down that light stays on too..so basically no dash lights will turn off if i try to. but once i turn my car off and on again, they all are off for the rest of the day...help?
Old Oct 6, 2010 | 08:07 AM
gidiup's Avatar
gidiup
In..
Sounds like a trip to the dealer is in your future.
My guess is it has nothing to do with the cold.
Old Oct 6, 2010 | 08:24 AM
neox's Avatar
neox
^ what he said...
There's probably a wire grounding out somewhere in your car thats confusing the ECU into throwing all kinda of instrument cluster lights. This is more likely caused by hitting bumps/turbulence inside your car rather than the cold weather.
Old Oct 6, 2010 | 09:03 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Are your speedometer and tachometer functioning?
Old Oct 6, 2010 | 09:07 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Oct 6, 2010 | 03:21 PM
Zing!'s Avatar
Zing!
Have your battery tested, check your drive belts
Old Oct 6, 2010 | 03:23 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
Well, I am in MN and let me tell you the car doesn't like cold weather much...but, regardless, that is not the source of your electrical problems.
Old Oct 11, 2010 | 04:25 AM
slo_latino's Avatar
slo_latino
Speedo and tach working fine. Guess its b/c of hit any hard turns and bumps. Damn coils. Thanks, ill be bringing the car to the dealer soon.
etkms
Jun 19, 2022 06:30 PM
416blueZ
Sep 25, 2015 10:00 AM
AbyteZero
Sep 22, 2015 09:17 AM
Darkspy
Sep 7, 2015 09:09 PM
