What's the minimum volts needed on the battery to start the car?
Old Oct 18, 2010 | 08:35 AM
themadhatterxxx's Avatar
themadhatterxxx
Default What's the minimum volts needed on the battery to start the car?
So I got this Smart Start function on my Viper alarm system where I can get the car to automagically remote start and run for about 45 min. when the battery's voltage drains to a certain level...What's the minimum voltage needed to start the car? Is it 12V?
Old Oct 18, 2010 | 09:08 AM
bmccann101's Avatar
bmccann101
its not a question of voltage, its a question of amperage. and a dead battery is actually 11.5 volts, even tho you may still be albe to get it to crank.
Old Oct 18, 2010 | 09:47 AM
themadhatterxxx
Well the reason I phrased it that way is because my remote starter manual reads:
"...The vehicle battery voltage is also monitored and if below 10.5 Volts the engine will start. The battery threshold can be changed by an authorized Directed dealer if a higher or lower threshhold is desired..."
Ideally I want this to remote start my car and run for a bit during the week while my car sits in the driveway, what value would I want to set it as the minimum so that it turns on before I can't start at all say during a cold winter morning? I few years ago I read somewhere on these forums that the minimum was 12 volts on the gauge on the center console but I'm not exactly sure...
codek
Sep 27, 2015 03:21 PM
Katie93
Sep 15, 2015 05:57 PM
Darkspy
Sep 7, 2015 09:09 PM
