My Z died while I was driving and now won't turn on.
Old Dec 11, 2010 | 06:53 PM
  #101
Edg_R's Avatar
Edg_R
Originally Posted by 350zion
I been thinking about the crank shaft position sensor... But I jus thought of something stupid . You have an auto... If the car is in gear the results your getting would be typical... Even if the selector looks like its in park it might not be.. Try putting it in neutral or turn the ignition while running it through all the selections.. If the switch that prevents you from starting the car in gear is faulty the car could be thinking its in gear Wen its not.. Wen the Guy towed the car he had to shift it into neutral to move it... Make sure u push the selector all the way forward... I bet that's the issue.... I hope you followed my rant....lolz lemme kno.....
The manager of the stealership said this as well. He said that he thinks it's either this, the ECU, or the gas pump.
You're smart.
Old Dec 11, 2010 | 07:01 PM
  #102
350zion's Avatar
350zion
Professional
My man I hate annoying **** like this... Too bad I didn't think of that sooner.. Could of saved you a ton.. Hopefully those basterds don't Jack you... Keep us posted.. Good luck brother!
Old Dec 11, 2010 | 07:29 PM
  #103
Edg_R's Avatar
Edg_R
Thanks! I heart your avatar, btw.
Old Dec 12, 2010 | 06:11 AM
  #104
350zion's Avatar
350zion
Professional
Yea meng...
Thanks!
Old Dec 12, 2010 | 06:19 AM
  #105
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default Tough...
times but good luck on the fix.
- RB.
Old Dec 12, 2010 | 09:00 AM
  #106
Edg_R's Avatar
Edg_R
Thanks, RB
Old Dec 12, 2010 | 06:31 PM
  #107
BoomerZ33's Avatar
BoomerZ33
You're smart.
at least you're narrowing it down to those 3. and yea it's the ***** that make him smart.
Old Dec 12, 2010 | 10:19 PM
  #108
winchman's Avatar
winchman
I'm liking the neutral/park safety switch as the culprit. It's much more likely to have intermittent symptoms when it fails or gets out of adjustment. It's also a much less expensive fix than replacing the ECU or fuel pump.
Old Dec 13, 2010 | 10:07 AM
  #109
350zion's Avatar
350zion
Professional
ˆtru dat...
Yes Steve its the *****!lolzzzz
Old Dec 13, 2010 | 02:40 PM
  #110
Edg_R's Avatar
Edg_R
They called today and said it should be done by tomorrow. They said that the cables coming off the battery were broken. (?) and that there was a fuse that was broken, which wasn't in the fuse boxes.
$690 to fix it. Not bad? at least Ill have a working car.
Old Dec 13, 2010 | 03:08 PM
  #111
ndilo21's Avatar
ndilo21
I'm sure that had to do a bunch of diagnosis, but $690 for some new battery cables and a fuse? That's why its called the stealership. Did that at least include the tow?
Old Dec 13, 2010 | 03:51 PM
  #112
Edg_R's Avatar
Edg_R
Yeah it did.
Old Dec 13, 2010 | 04:22 PM
  #113
BoomerZ33's Avatar
BoomerZ33
ahh so the problem was electrical all along. yeah dude that's a rip off. too bad if you were local i would help ya or take it to my friend's shop and save you some dough. good to see the car will be running again.
Old Dec 13, 2010 | 04:34 PM
  #114
350zion's Avatar
350zion
Professional
I wouldn't trust that one.... Those ****ers will get u like a modern day pick pocket.. A fuse is blown all the time not intermittently? if the battery cables were beat , Wen u turned the ignition on there would be no power and Wen u cycle the ignition fully the dash lights would prolly have gone out. Due to arcing from loose/ frayed cables the interior and ignition lights would of atleast once throughout this whole ordeal failed to work...
I smell a rat!
I really hope u don't experience this sheit again.. Like Steve said if u were local we would be more than happy to help out!
Old Dec 13, 2010 | 04:44 PM
  #115
BoomerZ33's Avatar
BoomerZ33
good call Ray!
Midtx, didn't you say you fully inspected the battery terminals and cables? you would've seen the damaged cable if you traced it around the motor. And which fuse exactly did they say was blown? they just told you "a fuse"?
you need to get some more details about their inspection method and how they made their final determination before you commit to this shady dealership
Old Dec 13, 2010 | 04:46 PM
  #116
Rocknthehawk's Avatar
Rocknthehawk
I smell a rat!
Not necessarily true. In my experience, if the cables are corroded, you'll have power to everything, but it won't crank. I chased that problem on a past vehicle.
Old Dec 13, 2010 | 05:03 PM
  #117
Edg_R's Avatar
Edg_R
I'll have more information tomorrow. They still have the car and i'm assuming they'll explain everything to me once I'm there to pick it up. I'll be sure to ask the questions that 350zion was asking. I checked the cables as best as I could and I didn't see anything when I had the car, but they said that it was further down, I guess by the motor. Which I didn't check.
Old Dec 14, 2010 | 05:16 AM
  #118
350zion's Avatar
350zion
Professional
Good luck, I really hope its fixed.. Trouble shooting is a PITA.
Old Dec 15, 2010 | 11:20 PM
  #119
RetchedOne's Avatar
RetchedOne
updates?
Old Dec 16, 2010 | 01:05 AM
  #120
midz350's Avatar
midz350
He sold the car.
