Air temp. gauge not working. (----)
Old Dec 4, 2010 | 04:30 PM
Z_enthusiast's Avatar
Z_enthusiast
Default Air temp. gauge not working. (----)
After installing my double din and TRYING to use the relay bypass for the parking brake i realized that my temp gauge is reading (----) All fuses are good dunno what could be the problems... any ideas?
Old Dec 4, 2010 | 05:35 PM
DavesZ#3's Avatar
DavesZ#3
You didn't plug all the connectors back properly.
Old Dec 4, 2010 | 05:39 PM
Z_enthusiast
hmmmm let me go try that white box... i know the guages are plugged in. i searched about this and saw threads but no problems solved
Old Dec 4, 2010 | 05:46 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
temp gauge connector is up at the top. You probably did what i did when I converted my interior. I stuck the entire dash piece over the plug and didnt figure it out till it was all back together.
https://my350z.com/forum/2234839-post38.html
Look at the picture in my post here. Its the plug in the center of the picture with the foam on it.
Old Dec 4, 2010 | 06:37 PM
Z_enthusiast
double post sorry
Old Dec 4, 2010 | 06:45 PM
Z_enthusiast
no the top gauge plug was plugged in,all gauges were lit except the air temp option.
FIXED: i took the lower shifter trim peice off and theres a white box with three connectors,one white two gray. i unplugged the gray plug next to the white one while ignition was on then plugged it back in and it worked. temp is fine now. guess there was a loose connection...
Old Dec 4, 2010 | 09:57 PM
winchman's Avatar
winchman
"After.... TRYING to use the relay bypass for the parking brake..."
What in the world are you talking about?
Old Dec 5, 2010 | 06:40 AM
DavesZ#3's Avatar
DavesZ#3
^^^ That's so you can run the DVD when the car is moving.
Old Dec 5, 2010 | 06:38 PM
Z_enthusiast
exactly!! i saw how to do it on youtube but for some reason the relay was clicking to fast (just before the radio turned on)
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
SharX59
Sep 27, 2015 09:23 AM
