*Why does my Z start like this? (video)*
I am not too sure thats a vacuum leak, as a leak would cause the idle to bounce all the time and not just at start up.
This maybe a long shot, but my M3 had a similar issue and it ended up being a corroded and partially broken ground strap for the motor. At startup the starter was pulling so much current and using soo many things as a ground that all kinds of stuff blinked and the engine ran very rough.
I think Hal@Injected did this when he was tuning my car. He too noticed the drop in RPM's and told me he thought it was a vaccum leak.
Try cleaning the throttle body. I had an issue with my idle doing the same thing but it happened anytime that I took it out of gear to come to a stop (like for a light). Cleaning the TB solved my issue.
The throttle body gets a lot of carbon buildup on the butterfly. I'm not sure what it is about the carbon buildup that makes things go haywire but I can tell you take my "dropping idle" problem and low, rough idle were solved by cleaning the throttle body.
Justin100
Nov 29, 2015 03:58 PM
