Engine Overheating, Advice please..
Old Dec 26, 2010 | 09:21 AM
cityslick43's Avatar
cityslick43
Default Engine Overheating, Advice please..
Hello everyone, I have an 05 automatic enthusiast, my engine has been overheating. 2 minutes into driving it my C/H gauge starts acting up and 30 more seconds its all the way to the top "H". I just replaced my thermostat, and also let all the air out of the pipes. I don't know what else it could be. I replaced the thermostat 3 days ago and today its starting to act up again.
Any Ideas? I really wanna drive my car, any advice would be great!
P.S I wanna get this done today because its my only day off.
Any suggestions would be very appreciated.
Old Dec 26, 2010 | 10:57 AM
Kwame's Avatar
Kwame
Either you still have air in your coolant system or your new thermostat isn't operating properly.
Old Dec 26, 2010 | 11:20 AM
R350Zz33's Avatar
R350Zz33
is it overheating while not moving ? also pick up a spill free funnel to properly bleed out air
Old Dec 26, 2010 | 12:05 PM
AJCaron12's Avatar
AJCaron12
Do you have a coolant leak? How does the overflow bottle look?
Old Dec 26, 2010 | 12:45 PM
cdoxp800's Avatar
cdoxp800
I am going to say you have air in the system someplace.
Old Dec 27, 2010 | 07:43 AM
DaveJackson's Avatar
DaveJackson
Master
Sounds like air to me, too. You need to verify if it's actually over heating though, or if your sensor is lying, (external infrared thermometer or similar.)
Apparently it's extremely difficult to not end up with air in these systems and there are explicit instructions and lots of threads about it. Maybe I am just lucky, but by actually filing it as slowly as they say, (which is painfully slowly), I have never had an issue. (With the bleeder open and all of the other instructions, etc...)
Old Dec 29, 2010 | 10:13 AM
cityslick43
Went to dealership there is a small crack in the radiator, I am going to get it fixed but can someone tell me how I can take a radiator out a 2005 350z enthusiast. I need this done today, you guys would really save me
Old Dec 29, 2010 | 11:28 AM
DaveJackson
Master
Re: Removing rad.
Do a search for the factory service manual first as it has decent instructions. There is one available on here, I think. I can't recall too many specifics, but it isn't that hard. Remove that plastic engine shroud first, for sure. Duh, make sure it's cooled down. Get the upper and lower rad hoses off and have an enormous tray there to collect fluid that will continue to drip for a LONG time. Give those 2 plastic clips a half turn and lift it out very carefully as it's pretty fragile with the fins and all.
Oh, I suppose there's the fan shroud too. It has at least two electrical connections. You'll have an easier time if the front of the car is jacked up.
Sorry, I can't remember more as I'm sitting in an airport, but if this sounds too daunting, accept that you're in over your head now. Make sure you find that manual first, as it was a bit of help. If it doesn't look too hard, get into it and post any issues you have. I'll check back in the next day or so.
Old Dec 29, 2010 | 12:15 PM
cityslick43
Thank you very much dave.
Old Dec 29, 2010 | 12:27 PM
Kwame's Avatar
Kwame
You can turn those two plastic clips all you want but if you don't first unplug and remove the fan shroud and second remove the two bolts attaching the AC condenser to the radiator, you're not getting it out. Do yourself a favor and find the service manual for your car for free online and follow the instructions listed in it for radiator removal.
Old Dec 29, 2010 | 05:06 PM
DaveJackson
Master
Yep. That's what I meant to say when I tacked that on late... Careful with the a/c because it's hard-piped in (if you have a/c.)
Old Dec 29, 2010 | 05:19 PM
cityslick43
Hey guys im so proud of myself I took the radiator out by myself im gonna buy a new one tomorrow and put it in the condenser and the radiator gave me some trouble but im good, thanks for all the advice
Here is my car finished!
Old Dec 29, 2010 | 08:00 PM
winchman's Avatar
winchman
How about a picture of what was wrong with the radiator?
Old Dec 30, 2010 | 09:03 AM
cityslick43
already fixed the radiator w/ diagram wasnt too bad
Old Dec 30, 2010 | 09:26 AM
Kwame's Avatar
Kwame
Your posts are confusing, but good luck to you nonetheless.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
