Help my auto gear box wont move...
Old Jan 23, 2011 | 08:30 PM
vianuchi's Avatar
vianuchi
Thumbs down Help my auto gear box wont move...
I tried many different ways to shift the gear... but it wont move from P ///
No luck so far ..
any ideas ? engine starts fine..
kindly help ,,,
Old Jan 23, 2011 | 08:31 PM
vianuchi's Avatar
vianuchi
Its completely stuck in
P mode..
Old Jan 24, 2011 | 04:14 AM
R350Zz33's Avatar
R350Zz33
Push the Brake down and try
Old Jan 24, 2011 | 04:34 AM
350Zdj's Avatar
350Zdj
have you tried to fiddle with the "shift lock" ? it's right next to the lever
Old Jan 24, 2011 | 08:49 AM
qqqqball's Avatar
qqqqball
the rod on occasion will fall off the valve body, or get stuck there, either ways you have to drop the pan and look at it
Old Jan 24, 2011 | 10:25 PM
winchman's Avatar
winchman
The owner's manual will tell you how to use a screwdriver to unlock the shifter as mentioned in post #4 above.
The problem could be caused by a bad brake switch, but that's easy to rule out by checking the brake lights. It could also be the solenoid that locks the shifter or a wiring issue.
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
