Automatic Transmission Fluid
Old Jan 24, 2011 | 01:04 PM
aZn93's Avatar
aZn93
Default Automatic Transmission Fluid
Umm I just got done doing a automatic transmission flush at a sinclair dino lube. I just looked it up and they said to use only Nissan J matic fluid and other will damage my transmission. However there they said my car used a special additive. Did they use the correct fluid or am I going to have to go to a nissan dealership?
Old Jan 24, 2011 | 01:16 PM
350Zdj's Avatar
350Zdj
there are some other brands that comply with J or S matic standards. Double check with the shop. But if you're still not sure, it's better to be safe than sorry - get it changed at the dealer if you must. The tranny isnt cheap to rebuild
Old Jan 24, 2011 | 01:20 PM
burubuduy's Avatar
burubuduy
I wonder if valvoline maxlife atf fluid will work? Since its matic j too. Can anyone confirm?
Old Jan 24, 2011 | 02:47 PM
DavesZ#3's Avatar
DavesZ#3
If you are still in warranty, then you better be using the Nissan-J or it's replacement, the -S trans fluid.
lapham3
Oct 7, 2022 03:15 PM
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
