relearning the idle, help!
Old Jan 26, 2011 | 09:31 PM
venmichaels's Avatar
venmichaels
Default relearning the idle, help!
My car idles very rough.. You can feel the steering wheel shake and it starts to pulsate.. I just purchased this 04 350z Roadster 5a/t
The motor runs super strong, and it doesnt really have any issues aside from the rough idling.. I tried to relearn the idle by following the procedure, but no luck.
Does the dealership have a scanner they can use to relearn it for me?
Old Jan 26, 2011 | 10:00 PM
scoobyrex247's Avatar
scoobyrex247
i'd do a compression test and a leak down test.
Old Jan 27, 2011 | 03:11 AM
DavesZ#3's Avatar
DavesZ#3
IS you idle lower or higher than normal? If not, then the relearn probably won't help.
Did you try all three procedures?
If not, read this... https://my350z.com/forum/engine-and-...procedure.html
Old Jan 27, 2011 | 07:25 PM
dcastillo819's Avatar
dcastillo819
Yes the dealerships do have the scanners to relearn idle if that's what u think ur problem is.
Old Jan 27, 2011 | 07:30 PM
TheFarmer's Avatar
TheFarmer
You can relearn the idle yourself by disconnecting the battery for ten days. If you're really concern, I would just bring it to a shop/dealer that knows more than you do and let them deal with it. If they cannot, test drive another vehicle similar such as yours and compare. Perhaps it's normal and you do not have to disconnect the battery for ten days.
Old Jan 27, 2011 | 09:46 PM
venmichaels
ive driven quite a few different Z's
This one's idle jumps around.. it will be fine for a few moments and then drop n want to stall..
liqalu04
Jan 2, 2022 12:58 PM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
