strange cooling issue.
Old Feb 23, 2011 | 11:08 PM
treymchattie's Avatar
treymchattie
Default strange cooling issue.
i recently installed a mishimoto radiator and shroud in my Z, filled her up and had no leaks. drove the car to work a few days, but the last 2 days i had issues. the drive home is all highway until i get off on the ramp and make a left. each time i got off my temp would jump from the normal "slightly below mid" to "almost max" and the needle bounces around a bit before finally going back to normal. to make it better my heater would start blowing cold air. i feel like i am not actually overheating because the needle jumps around faster than coolant could possibly cool off. (takes probably 1second to go from overheat to normal)
safe to assume i have bubbles in my system somewhere? im guessing the left turn is putting air through my temp sensor and heater.
Old Feb 23, 2011 | 11:11 PM
JPsZ's Avatar
JPsZ
How did you bleed the system? There is a bleeder valve in the back passenger side of the engine bay, close to the battery compartment.
Old Feb 23, 2011 | 11:15 PM
JPsZ's Avatar
JPsZ
Old Feb 23, 2011 | 11:32 PM
treymchattie
wow i feel like a tard.
been doing watercooled computers for years, i just assumed that as long as water is moving it would bleed all the air bubbles.
thanks man.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Twenty4
Jan 17, 2016 01:20 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 30, 2015 10:54 AM
