Cooling issue on 03 Z
Old Feb 26, 2011 | 05:37 PM
BristishZ's Avatar
BristishZ
Default Cooling issue on 03 Z
Got up today and drove to work. After 7 miles or so wondered why the heater in the car was blowing cold still. Looked down at the temp. guage and it was just above normal. I would stop at a light and then go and as i would leave the line the temp. guage would go up to about inbetween hot and normal. Then it would settle back down just above normal once driving for a little bit. like a few hundred yards. All this time the heater is blowing cold. Check the coolant and it was maybe half a quart low but its NEVER had any problems over heating. im going to check to make sure both fans are working tonight. any ideas? its only an average of 45 degrees out side. Not even hot. Any help would be awesome thanks guys!
Old Feb 27, 2011 | 04:56 AM
grimm66's Avatar
grimm66
You most likely have air in the coolant system. Burp the system and you should be fine... If not the try changing the thermostat.
Old Feb 27, 2011 | 09:17 PM
BristishZ's Avatar
BristishZ
Thanks. i topped up both the expansion tank and the radiator maybe for a total of 1 quart and its fine now. i will keep an eye on it and see if i can find out where its going.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 30, 2015 10:54 AM
