power window & power lock button unresponsive
Old Mar 27, 2011 | 11:43 AM
soporific88's Avatar
soporific88
Default power window & power lock button unresponsive
Hi there, like my title thread said I am having problems with my power windows & power locks on both the passenger and driver side. The power mirrors do work, but everything else doesn't. I have tried looking for blown fuses, but they all seem to be fine. I was wondering if anyone has a solution to my problem. Thanks in advance.
Old Mar 29, 2011 | 10:16 AM
winchman's Avatar
winchman
There's a button on the driver's side armrest (forward and left) that will keep the passenger side window switch from working. I don't think if it does anything to the lock, though.
You should get a copy of the service manual for your year car, and see sections BL and GW.
Old Mar 29, 2011 | 01:19 PM
christol's Avatar
christol
One of the things we always check when more than one switch is inoperative in the door is a broken power feed in the harness boot going to the door. Quick check - try to pull the rubber boot out of the door so you can get to the actual wiring. Pull on each wire - if you can move one quite a bit, it is likely broken. Happens often in door harnesses due to the constant opening & closing.
Old Mar 29, 2011 | 01:21 PM
christol's Avatar
christol
And if that doesn't work -- get a wiring schematic and pull the switch panel. Check to see if you have power to the switches.
Old Apr 2, 2011 | 01:36 PM
soporific88
Thanks for the replies, it was actually working this morning, but now won't respond again lol
Mattg350z
Oct 2, 2015 06:51 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
