Nismo Cluster Install, TCS/Slip is ON, Related ? ? ?
Hey all,
Just put in a Nismo 300km/h cluster into the car and now the TCS/Slip is on.
I wonder if this is related at all?
The light do not come on immediately after I start the car, it only come on after I slowly move the car.
One more small issue, I also put in a aftermarket Momo steering wheel with the HKB hub. Felt great, but the "auto-signal shutoff" is no longer working. Any idea on this one?
Much appreciate, sorry for the newb q's, 2004 z33 fairlady owner
Cheers
Chris
Cheers
Chris
I suppose I can just remove the Momo again and align the clock' spring?
I did not do the install myself, but I would like to get this sorted out if I can
thanks
The spiral cable (clockspring) installation is covered in section SRS of the service manual. It tells you how to install it in the neutral position, so it won't get damaged by normal movement of the steering wheel.
