Oil psi gauge and volt gauge position
Old May 4, 2011 | 06:54 AM
x2jesse1x's Avatar
x2jesse1x
Default Oil psi gauge and volt gauge position
I was doing an LED swap on my center gauges. I changed out the gauge face And had to pull the needles. Well i assumed that since the car was off when i removed the cluster the gauges needles could be reinstalled on 0. I guess I was wrong.
How can I find the correct reading for these gauges so i can install the needles correctly?
Old May 4, 2011 | 08:44 AM
DFW Z33's Avatar
DFW Z33
I am salad
wow, that'll be tough for the oil psi. my best bet would be to get a mechanical oil psi guage, hook it up to your car and adjust the needle so that the values match. As far as the voltage, that should be easy. Just get a multi-meter, and turn the car on to get the operational voltage... usually about 14 volts, and then put the needle on to match that voltage. sounds like you got yourself into a pickle.
Old May 4, 2011 | 08:50 AM
x2jesse1x's Avatar
x2jesse1x
Would my oil psi not be the same at idel as everyone else
Old May 4, 2011 | 08:56 AM
R350Zz33's Avatar
R350Zz33
Every motor is different depending on type of oil ect ect
Old May 4, 2011 | 11:17 AM
Spork's Avatar
Spork
You're supposed to pull the needle stopper and mark where the needle lays. Reinstall according to the mark. Should've asked before you did anything.
Old May 4, 2011 | 11:35 AM
x2jesse1x's Avatar
x2jesse1x
Really? Thats for the info..... Anyway like I stated previously I figured since the car was reading zero with the car off i could just replace the needles back to zero
apex locator
Jul 23, 2021 02:27 AM
Depravity
Oct 1, 2015 04:49 PM
