Plenum Spacer + Silicone Gasket sealant?
Old May 11, 2011 | 03:31 PM
J-P-T's Avatar
J-P-T
Question Plenum Spacer + Silicone Gasket sealant?
Hi guys,
I'm re-installing a ~0.59 inch thick plenum spacer on a 350z and I noticed the previous owner used some orange colored silicone sealant between the top intake plenum-half and the spacer, but did not use any between the bottom of the spacer and intake plenum gasket. Since this is my first time doing this and I don't know what brand the spacer is, is it okay to use silicone gasket sealant again on this top portion of the spacer and leave the bottom part alone? (new gasket is being installed too)
Old May 11, 2011 | 05:38 PM
david79's Avatar
david79
i would suggest to take that spacer out and put in a 5/16 instead.
Old May 11, 2011 | 06:49 PM
If gaskets are new there is no need for sealant. Have no idea about condition of used gaskets.
Old May 11, 2011 | 08:23 PM
J-P-T's Avatar
J-P-T
any reason why? I read the reviews and comparisons and it seems like bigger spacers where making bigger power due to the volume increase in the intake manifold. Besides, I don't have a choice in getting something else, just re-installing after an injector upgrade .
Old May 11, 2011 | 08:36 PM
ddc665350ztt's Avatar
ddc665350ztt
i would just put a really thin bead of sealant just in case. it wouldnt hurt...
Old May 12, 2011 | 10:15 PM
J-P-T's Avatar
J-P-T
Question
I noticed the Motordyne tutorial calls for covering the lower intake manifold gasket in oil, but if I'm using an OEM Nissan lower intake manifold Gasket, do I just leave it as is? Or, do I also cover it in oil? Thanks..
Old May 13, 2011 | 07:20 PM
ddc665350ztt
make sure its clean. both the gasket and the other surfaces. the motordyne gasket is a made out of another type of material which i guess works better oil saturated.
Old May 18, 2011 | 12:29 PM
bikinilust's Avatar
bikinilust
Ive installed spacers many times... new and used.
I typically run a thin bead of black rtv as insurance, on used spacers.
Its a crap shoot if the used spacer gasket is gonna leak or not.
Old May 18, 2011 | 12:31 PM
bikinilust's Avatar
bikinilust
im not saying all used spacer gaskets leak, but ive come acrossed a fair share of them to warrant going ahead and just use the black rtv.
Old May 18, 2011 | 12:48 PM
e46330i's Avatar
e46330i
You might as well use a sealant. It's not required but it doesn't hurt to have in case yours does leak.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
